Results 1 to 4 of 4
Thread: alternator light at 4000 and above
    Jun 2002
    87 Accord DX Hatchback 5 Speed
    Cocoa Beach, Fl.
    I've never had this happen before, and have not heard of it so I need help. My alternator light comes on around 4k rpm and stays
    on while at or above 4k. No problems at any other times and the system is recharging OK since if it wasn't it would have been dead by this time. I haven't done a thing, like clean terminals, etc. Anybody got any ideas?
    1988starter
    Guest
    Put a voltage meter on your battery while the car is running and see what the alternator outs out then have a friend rev the engine till the light comes on and see if what the volage is. You should see between 13.5-14.2 volts
    check the belt tension 1st, it doesn't always squeal when it's loose
    2nd could be worn out brushes
    Eric
    1986 Honda Accord EX (1.6) carb Manual
    Karachi Pakistan
    your alternator brushes are worn out, I got the same problem - relplaced the brushes and good as new...
  1. battery light @ over 4000 rpms
    By roofusgooner in forum 3geez Accords
    Last Post: 07-06-2008, 10:07 PM
  2. Alternator light flickering
    By visionguru in forum 3geez Accords
    Last Post: 11-11-2006, 08:58 PM
  3. Alternator / alternator light pbs
    By lionel in forum 3geez Accords
    Last Post: 12-13-2005, 01:36 PM
  4. Alternator light question
    By SeanTypeR in forum 3geez Accords
    Last Post: 06-09-2004, 07:04 AM
  5. Alternator Light
    By Osiris89LXi in forum 3geez Accords
    Last Post: 01-14-2003, 11:53 AM
