Results 1 to 12 of 12
Thread: Power Steering removal???
    1988 Laguna Gold DX Coupe
    Alpena, MI
    Is there reall y that much power to be gained? Is it worth trying to manuvere my 15's around manualy? Can I just cut the belt to do it?
    '88 DX Coupe, Laguna Gold, auto, carbed, pedal covers, 5.25" Pilot Motorsports Resonator Tip, flipped lid, cut A/C belt, 15" Saturn aluminum Wheels with Firehawk GTA's, Aiwa CD deck, Jensen 6x9's and Boss 5.25 speakers, red honda emblems, red wiper arms, Sunroof, blue neon in back window.
    Soon to add underbody red neon and possibly EFI???????
    1988starter
    Guest
    Maybe, NO, Yes. Now if you really want to see what is up just loosen the belt and remove it do not cut it if you do not like it just reinstall the belt. That is what I did and I put that belt back on right away.
    LX User 89accordlxi's Avatar
    see user name
    IA
    Yes, you will notice a little more pull from the engine. I didn't like not having the power steering though so I put the belt back on after a day of struggling to turn the car. If you are going to race your car then yeah go ahead and remove it since when you race you are just going in a straight line. But for everyday driving, I just couldn't live without the powersteering. Those are just my thoughts and opinion on the topic. I'm sure there are others that will prefer other wise.
    Peace out..
    89 Lx-i
    Performance: K&N filter,custom CAI, Accel coil, MSD 6aL ignition, magnecor wires, high flow injectors, FPR, sport exhaust,Tokico springs/struts
    Appearance: white gauges, side markers, headlight conversion, clear bumper signal/fog light conversion, SE-i center armrest and cupholder, SE-i leather seats
    17" ADRs with 205/40/17 khumos
    future plans: 16" or 17" rims(can scratch that one off the list 9-12-02), headers-high flow cat.-cat back piping. Rear disc brakes from SE-i, reground cam.
    i dunno, depends on your driving style and if you can tolerate living without power assist. You won't gain much, you can test your "gains" (should be called "recoveries" lol) by taking off the belt but be warned, fluid will probably pump out (it isn't getting circulated and when you turn the wheel you pump it around and it overflows the tank)
    Eric
    1989 accord lxi
    i think if you do decide to get rid of your power steering you not only have to get rid of the belt, you have to drain the fluid so you dont have to punp it out when you steer, not as hard as you think once you remove the fluid, with the fluid,u might as well just drive into the side of a building
    peace
    fussell
    Alpena, MI
    Nah, that's okay I'll leave my power steering on.
    1/2 JDM B18A DOHC CARB
    MD
    Hey, I removed my power steering and I've been happier ever since. Definitely not for the weak, but I've gotten used to it.
    Carl
    Banned
    Nov 2002
    87 Honda Accord Lxi
    Tempe, AZ
    so all I need to do is drain all the fluid from my ps, and remove the belt? I probably wont have to worry about that because it will all probably leak out first. but it wont start makin any wierd noises will it? (yeah I know this is a reeeeally old post but i dont care because I need to know how to do it!)
    Oct 2002
    '89 Prelude Si 4WS
    Gig Harbor, WA
    draining the fluid will be hard on your rack... power steering racks need to stay lubricated to keep from burning out... if you really want to get rid of it and keep the shorter rack, and you don't want the difficulty of turning as it is without a belt, just bypass the pump... simply take it out of the equation... it will be a bit harder to steer, yes, but you'll keep the rack lubricated, and you won't run the risk of overflowing the resevoir...
    http://www.merlindavis.com
    SEi User MoonScryer's Avatar
    1986 Prelude 2.0si turbo - 1990 Integra moutain carver - 1993 Nissan 300ZXTT w/ more power than god
    Atlanta, GA
    ..... or just take the hardlines that come in and out of the valve body on the rack itself and have a new short hardline made to go from the out to the in. Make sure there is fluid in the line, and that is it.
    or get a manual rack.
    Oct 2002
    86 LUUUDE
    Kelowna BC Canada
    woooohoooo i got rid of my PS... and i got rid of the reservoir and all the lines and everything.. i crimped the lines down at the bottom near the firewall on the apssenger side and everything.. just one question though... is there coolant going to the powersteering rack from that huge coolant tube because i am putting my motor back in after getting rid of this and i have an opening and nowhere for that hose to go...
    BTW merlin davis.... how long ago did u start lude conduct??? cause we have had it up heer for a couple years already
    SEi User od2681's Avatar
    Nov 2002
    2003 Infiniti G35 sedan
    Houston Tx
    wouldnt that hurt ur power steering..i mean removing belts and crap
  1. power steering rack removal
    By 1988 in forum 3geez Accords
    Last Post: 12-13-2016, 06:24 PM
  2. power steering rack removal tips
    By lostforawhile in forum 3geez Accords
    Last Post: 01-20-2007, 12:04 AM
  3. Good lord power steering sucks power!
    By 87DXHatch in forum Classic Honda Community Chat
    Last Post: 08-30-2005, 05:20 AM
  4. power gained from removing power steering?
    By Mantis88LX in forum Performance
    Last Post: 04-10-2003, 06:50 AM
  5. Power Steering Removal Memoirs
    By RL89LXi in forum 3geez Accords
    Last Post: 07-01-2002, 07:31 PM
