Results 1 to 6 of 6
Thread: what does 6 flashes on ecu mean?
    Jul 2003
    89/honda/accord lxi
    Jax, Florida
    I have an 89 lxi and the ecu flashes 6 times. I think it has to do with the fuel sysytem since I just changed my filter. Please help thanks.
    Jul 2003
    1987-Gen2 Honda Prelude-FF-2.0L-MPFI-4 Cyl-5 Spd-PWR-BLK
    Ottawa
    engine coolant temp sensor
    Jul 2003
    89/honda/accord lxi
    Jax, Florida
    Would this failed sensor have anything to do with my cooling fan coming on at odd times like 2 hours after the car has been parked? Is it pretty easy to replace?
    Jul 2003
    Ottawa
    no idea man...I own a prelude...I dont have the same car....just the same engine!
    Jul 2003
    Ottawa
    wait a sec....it is easy...I know where it is...its on the thermo housing I THINK!
    One bolt is comes out.....screw the new one it and hook it up
    Good to go!
    Vinny's Avatar
    Aug 2003
    Here, not there
    it is on the thermostat housing and it takes a 17mm deep socket to remove it I believe. And no its doesn't have anything to do with your fans. I beleive on the 88-89's there are 2 sensors for the fans, there is one in the bottom of the radiator and another in the thermostat housing but I'm not totally for sure on that one since I'm still waiting on my electrical service manual. I think thats the one that lets the fan run for so many minutes after the car shuts down if the temps above a certain point. Anyways back to the point. A bad Coolant temp sensor is more of an idling, stalling not starting type problem. HEres a link for ya to read
    Intermittent Starting Problem & Irregular Idle...FIXED FIXED FIXED ! ! !
  1. 0 flashes on the lil LED
    By kretty in forum EFI Tech
    Last Post: 11-19-2011, 04:21 PM
  2. ecu flashes 13 times. BARO sensor?
    By Josh89accord in forum 3geez Accords
    Last Post: 03-02-2009, 09:32 PM
