Even if you use light oil, surprising power gains can be made by keeping oil away from the rotating parts in the crankcase. Crank scrapers are easily fabricated for any engine, and so are custom oil pans using billet pan rails.
It basically has to do with keeping oil off the crankshaft. … If you lighten the crankshaft itself up, from a rotational standpoint, … that car will move from point A to point B faster. It won’t show up as dyno power, but it will show up on the stopwatch.
But in any event, assume that oil passing by the crankshaft and pulses of air created by rapidly descending pistons and the volume of air entrapped up inside them will combine to increase the importance of reducing the amount of oil that becomes a “passenger” at high crank rpm.
