Results 1 to 10 of 10
Thread: Carb VS EFI
    Nov 2003
    Carb VS EFI
    Which is faster, an EFI accord, or a carbed? Which has more potential?
    NXRacer's Avatar
    86 LXi Hatch
    Tri-Cities, WA
    depends on how much money you want to spend. The EFI comes with more HP stock. You can get carb upgrades (dual side drafts etc) or you can go with turbo on either one with Seans turbo kit (look in my sig for details).
    What are you looking to do with your car in the long run?
    Nothin' 2 Old Racing
    Bloodlust's Avatar
    1989 LXi Coupe (SOLD), 1998 Accord EX
    Line Lexington, PA
    IMO EFI has more potential. But then again, I dont know much about carbed cars.
    Thinking about getting a new 3g...
    EFI. like mike said its more potential. Plus more horse power stock. Just my openion.
    DeathRat's Avatar
    Aug 2003
    95 Chev C1500 Truck / 90 Cavalier Coupe (sold)/ 88 Accord LX Sedan (sold)
    Edmonton, AB Canada
    Re: Carb VS EFI
    Define "FASTER"? Stock - wise? Or if you mean "suped up", well then that's a whole different ball game then. As for "Potential" that depends on the old $$$ in your wallet! I perfer Carbs due to less that can go wrong with them. Electronic Fuel Injection can give you nightmares when it goes wrong. Carbs being mechanical in nature, are usually easier to fix as you've only got a finite number of things that can go wrong with them.
    k-roy's Avatar
    87 LX
    Weber DCOE's rule hardcore.
    They have won thousands upon thousands upon thousands of races.
    I once saw a Mustang with 4 DCOE's run a 10.2 N/A 1/4 mile.
    MIK3's Avatar
    Jan 2003
    1988 Accord DX
    Phoenix, AZ
    I have only experienced carbed, so I wouldn't know much about EFI. All I know is that life will be a little more easier with EFI, if it is not problematic. Stock EFI comes with about 22 more hp, but is less fuel effecient, if I am not mistaken. You need to ask more questions man. More precise questions will give you more precise answers grasshopper.
    -Strugglebucket
    redaztec
    DAYUM!
    2ndGenGuy
    MessyHonda
    k-roy's Avatar
    87 LX
    Good point mik3.
    If the stock carb flowed more fuel and had the higher compression like the efi it would have more similar power numbers. The only main advantage of efi is emissions. Carbs make no less power than a equal pgmfi setup.
    MIK3's Avatar
    Jan 2003
    1988 Accord DX
    Phoenix, AZ
    Bah. Almost forgot about that stupid thing. Yeah. Welcome to the world of emissions if you want to invest in carburetion. And potential wise. Well, both cars have potential, that is not an issue. The issue there is money.
    -Strugglebucket
    redaztec
    DAYUM!
    2ndGenGuy
    MessyHonda
    carbed is a much better choice unless you have a fully programmable EFI, otherwise you need to burn a new chip for each mod
    Eric
  1. carb idle issues caused by carb temp sensor discuss
    By lostforawhile in forum Carburetor Tech
    Last Post: 01-28-2017, 01:51 AM
  2. Help carb gods! I need help! Carb has issues!!!!!
    By 86ccord in forum Carburetor Tech
    Last Post: 03-03-2011, 05:13 AM
  3. Replies: 7
    Last Post: 12-13-2005, 07:16 PM
  4. 87 dx Carb compatible w/ any other Honda Carb?
    By A2B Accord in forum Carburetor Tech
    Last Post: 08-13-2003, 03:20 AM
