Results 1 to 14 of 14
Thread: Prelude Dual Carb Swap
    DeathRat's Avatar
    Aug 2003
    95 Chev C1500 Truck / 90 Cavalier Coupe (sold)/ 88 Accord LX Sedan (sold)
    Edmonton, AB Canada
    It's my understanding that the only way to effectively use a dual carb setup from a 84 Prelude is to swap the Cylinder head over too? I base this on this thread >>>> https://www.3geez.com/showthread.php?...ight=Dual+Carb
    Is this true? Reason being is I can get the dual carbs & intake for $20 CAN from the wreckers & my A20A1 single carb just doesn't have enough "oomph" for me.
    PhydeauX's Avatar
    Eastern Penna
    Yes you have to swap the whole head, the intake ports on the a18a are diferent then the a20. They problaby won't charge you more then another $30-40 for the head anyway (just make sure its still good). Its easier to remove the head to change the manifold then doing it with the head on anyway.
    andy
    DeathRat's Avatar
    Aug 2003
    Edmonton, AB Canada
    What about my Distributor? OR should I grab that too?
    PhydeauX's Avatar
    Eastern Penna
    Its got a little bit more mechanical advance, other then that its the same part.
    andy
    DeathRat's Avatar
    Aug 2003
    Edmonton, AB Canada
    Thnx! It's just while looking for a Air Intake to mod my present setup, I noticed 3 other Preludes there with Dual Carbs & then started thinking.....:super:
    LX User 4DoorAccordDX's Avatar
    1987 Accord Sedan DX 5-Speed, 1977 Chevy K20 350ci 4-Speed, 04 Yamaha Raptor
    Monmouth, OR
    How hard is this swap? Will this eliminate most of the vaccum lines that we have now? What about emissions, how will it affect the Nazis down at the testing center? Just kinda curious what is involved, and how had it is to do. The lude has an A18 right? Will the heads match up as far as all the water passages and all that go?
    Thanks in advance for any and all info.
    2-Knee
    May 2003
    u got to make sure u get a head off of a 86-87 lude only. from 84 back it will nto match up. the head off of the 86-87 head tho everythign matches up perfect, u have to get teh head bored out to a 2.0 also
    DeathRat's Avatar
    Aug 2003
    Edmonton, AB Canada
    So I still have to get the Cylinder Head bored too? Even though it's a "perfect" match?
    k-roy's Avatar
    87 LX
    Its the bore and stroke in the block that defines displacement, not the head. The head determines the compression ratio.
    yea, you may actually get more compression b/c the combustion chamber is probably smaller too
    DeathRat's Avatar
    Aug 2003
    Edmonton, AB Canada
    That's what I thought too......
    May 2003
    hmm i dont kno guys i kno a few gusy with thsi head and blcok combimnatin on there ludes and they had to get the head bored to the same diameter as teh block.
    SEi User BMS's Avatar
    88 LX / 97 Teg
    California
    Let's say that someone who lived in Cali wanted to try such a trick...I am sure that it'd still pass the smog test, but would it pass the visual inspection?
    1986, Prelude
    Calgary, Alberta Canada
    Yup, i'm with you man, if want reiability and don't want to be detonating then get the head combustion camber done to have the same bore as the cylenders.
    Hahahaha, have you ever seen under the hood of a stock prelude??? Vacume lines galore!!!! To complete he swap, you will also need the black vacume controll box that comes with the carbs and all of the vacume lines and a danm good manual to tell you where to hook them all up. Not worth it in my opinion, if you go with the Weber 38/38 you get more power than the prelude carbs and it will be one hell of a lot more easier. If you plan on a dual DCOE setup then yes get the prelude ET2 or A18 head.
    I ain't no junky...... I just keep it funky
    -Weber DCOE's
    -Colt Cams Stage II Triflow
    -Headers
  1. 87 prelude dual carb problems
    By esty in forum Classic Preludes
    Last Post: 07-01-2007, 10:53 PM
  2. dual carb
    By theDougler in forum Performance
    Last Post: 06-27-2005, 10:07 AM
  3. Dual Carb
    By Ludi Mali in forum Performance
    Last Post: 08-29-2004, 05:53 PM
  4. dual carb set up
    By pip in forum Carburetor Tech
    Last Post: 03-16-2004, 02:17 PM
  5. dual carb manifold
    By mykwikcoupe in forum General Engine Swaps
    Last Post: 02-07-2003, 10:26 AM
