Results 1 to 7 of 7
Thread: Just sayin high
    Nov 2003
    Just sayin high
    hi, new to the board, just picked up an 87 hatch yesterday.
    last night the block heater popped out of the block and i lost all coolant. fixed that today but didnt set the distributor before i removed it to get at the block heater. Now she wont start, im hoping i just need to adjust 360 degrees but im no mechanic so any ideas?
    replaced the thermostat and spark plugs, getting exhaust on monday.
    Has anyone had problems with the light switch assembly in the steering wheel hub?
    thanks for any help and its nice to find a good 3rd gen forum
    Glicko
    Banned
    2000 Civic LX
    Washington
    welcome to 3geez
    Accord of the Year - 2006
    guaynabo89's Avatar
    FL
    You live in Canada?
    THe dist will only go on one way cause the two teeth are slighly offset of the center.
    Backtrack your steps o make sure you didn't disconnect anything. Like coil wire etc
    1987 Hatchback phreak project
    NORTH BAY ONTARIO
    hmm... how do you know he is canadian?
    i have a broken headlight switch... i dont have the time to fix it.. so i just hold the base part and twist the switch
    Travis
    k-roy's Avatar
    87 LX
    Travis
    I have that same problam too. I went to the junkyard this weekend to get a new assembly and found out the hard way you need to pull the steering wheel to get it out. I think I will try using JB weld instead. I'll try it and tell you guys how it works out.
    guaynabo89's Avatar
    FL
    I don't,........ just asking. Not many people in the U.S. have block heaters
    Nov 2003
    oh hey i just noticed newB intro subforum, whoops.
    got it running, i was right, just had to rotate the distributor another 360 and adjust the timing a lil.
    yea im in canada, edmonton to be specific
  1. rpm to high
    By ghettogeddy in forum EFI Tech
    Last Post: 10-07-2010, 07:28 PM
  2. I'm New, Sayin Hey (Cheesy, I Know)
    By JBona in forum Classic Honda Community Chat
    Last Post: 11-11-2008, 01:50 PM
  3. High Rev A20?
    By Bass Man in forum Performance
    Last Post: 06-05-2008, 01:22 PM
  4. just sayin hi
    By krazy4 in forum Newbie Introductions
    Last Post: 03-27-2006, 07:43 PM
  5. Failed Emissions: High HC ppm's & High CO%
    By 98serwtricks in forum 3geez Accords
    Last Post: 06-15-2004, 09:24 AM
