i change the seal, o-ring, and cotion ring. it is still Leaking. where can i get a cheap injector? will the junk yard do?
The junk yard will work. It's best to get them from a pull-a-part yard so you can make sure that there is no fuel on the intake manifold. I had three leaky injectors and put in four used ones that have been working well for nearly 20k.
Mike
what i've been seeing is you should pull the injecto off an h22 pre obd2 though, just for the higher flow, i guess depending on your mods it will only hurt your gas mileage at first, but as you get more mods i think you'll be glad you did it
worrying is like a rocking chair, it gives you something to do but gets you nowhere
h22 comes out of which car again? or looks like what?
prelude....................Originally posted by 1987HondaAccord
h22 comes out of which car again? or looks like what?![]()
Greg
1989 LX-i 2dr 5spd (R.I.P.)
