Results 1 to 8 of 8
Thread: new Rear brake shoes and new drum install
    Aug 2003
    civic, accord honda sabre
    washington dc
    I have the rear brake shoes on but can't get the new drums to fit.
    The e-brake cable adjustment screw/nut is turned as far back as possible. My question? Does the brake shoes come with one side slightly larger than the other? If so does the shorter one get attached to the e-brake lever?
    SEi User Dibbs's Avatar
    May 2003
    '86 LX-i Hatch
    Houston
    Hopefully you haven't taken them apart for both sides. If not. Look on the other side to see how it all goes together. Or you could print this schematic out.
    Rear Brakes
    Quote Originally Posted by kroy
    Mad props to you if you can pull it off, you can change your name to slowassoldschoolswap :thumbdown
    SEi User 2old_honda's Avatar
    Nov 2002
    88 Accord
    Nebraska
    I have to to my rear shoes pretty soon. i havent really looked at it, but I was wondering how do you get the drum off of the hub? just make sure the e-brake is off and pry it off?
    May 2003
    '86 LX-i Hatch
    Houston
    Yeah. If you haven't wore your brakes out too much, they should slide right off w/o prying. If they are stuck, you'll have to use a brake tool. Take off the rubber cap behind the drum and use the tool to take the slack off the tensioner until it comes free. If your drum is stuck, it's probably best to go get it machined once you get it off. If they slide off easily, don't worry about it.
    Aug 2003
    washington dc
    Thanks for the replys. I asked around and turns out that the shorter shoe if I can say that goes on the front side left hand side if your staniding in front of the wheel hub.
    May 2003
    '86 LX-i Hatch
    Houston
    Right. If I remember, Both shoes are cut different so it's kind hard to swap them around.
    Justin86's Avatar
    Medford, Oregon
    or you can just use the bigger hammer theroy. It has never failed be before.
    Aug 2003
    washington dc
    The other problem was that the adjusting bolt ends where not turned so that the longer ends where on the outside they where on the inside.
  1. Rear drum brake servicing
    By nswst8 in forum Suspension/Wheels/Tires/Brakes
    Last Post: 04-07-2011, 10:54 AM
  2. Rear drum brakes install tips?
    By 1989accordaz in forum 3geez Accords
    Last Post: 12-24-2008, 09:56 PM
  3. How do you know when to replace rear drum brake shoes?
    By OptimusPrimeSr in forum Suspension/Wheels/Tires/Brakes
    Last Post: 07-08-2008, 04:23 AM
  4. rear drum shoes
    By ZackieDarko in forum Suspension/Wheels/Tires/Brakes
    Last Post: 11-01-2006, 02:07 AM
  5. :wtf: Rear brake drum -Help-
    By spnrx in forum 3geez Accords
    Last Post: 02-24-2006, 12:27 PM
