Results 1 to 7 of 7
Thread: alarm mounting . . . . . HELP ME
    2.0Si User accordlxi2.0's Avatar
    1986 honda accord lx (r.i.p) 1990 acura legend LS
    chicago , il.
    what would be the best spot to mount my alarm brain.
    i want it to feel the vibe's but i can't get it to unless i pound on the damn car.
    SEi User TJ89Accord's Avatar
    Oct 2002
    2006 Honda Civic LX
    Middletown RI
    mount it to a wire harness under the dash. Find a thick bunch of wires and zip it up there.
    chicago , il.
    so it should be abe to detect movement from it if i mount it on the wire harness?
    ****** 1994 nissan maxima SE ******
    Oct 2002
    2006 Honda Civic LX
    Middletown RI
    it should try to find a thick bundle of wires.
    S.Glastonbury, CT
    I personally never mount mine under the dash unless you cant reach it by hand. Why bother because a theif will be able to disable the system in seconds and there is not really any good spot under our dash that i have found to hide the brain well enough. The only thing extra you will have to do is extend the wires to the dash. I also uses a seperate power source since if you power it from under the dash you can easily see the connectors and would be disabled easily.
    Nov 2002
    Ridin Dirty in New York
    you have to make sure that the amp is not bolted or touching the case to ground, because that is not always a good scenario, it should be isolated from ground (the amp heatsink/case)
    LX User catalin's Avatar
    1986 Accord Hatchback
    Surrey, BC, Canada
    A pretty good place is above and behind the glove box. Kind of tough to get to and it makes for a clean install.
  1. Sirius Mounting
    By Francos Accord in forum Interior & Exterior Care
    Last Post: 06-17-2009, 11:31 AM
  2. Mounting new seats
    By 79cord in forum 1geez Accords
    Last Post: 04-12-2009, 05:54 PM
  3. Mounting Intercooler?
    By Rendon LX-i in forum Classic Honda Community Chat
    Last Post: 04-02-2009, 06:18 PM
  4. mounting subs
    By acco-R-d in forum Interior & Exterior Care
    Last Post: 03-24-2005, 07:30 PM
  5. I need the mounting bushing!
    By Mantis88LX in forum Suspension/Wheels/Tires/Brakes
    Last Post: 08-16-2002, 02:23 PM
