Results 1 to 7 of 7
Thread: Heat riser control.
    Feb 2003
    '86 Accord LX
    Kelowna, BC
    Heat riser control.
    Which thermovalve is associated with the heat riser? I want to put mine back on, but I ripped out all the vacuum lines, and don't know which thermovalve I should be using.
    James
    '86 Accord LX 5spd > Bought for a hundred bucks.....Canadian. Leaks oil, has lots of rust, and is about 5 different shades of green.
    Mods: True ram intake, K&N, vacuum line removal conversion, 14" aluminum wheels, $20 cd player, $20 speakers, dual barrel air horn.
    1987 Hatchback phreak project
    NORTH BAY ONTARIO
    lol.. i just made a HOT AIR intake for my carb.. its too damn cold up here in canada to run no airbox with a preheater... my carb always ice's up
    Travis
    Feb 2003
    '86 Accord LX
    Kelowna, BC
    So no one has any idea which valve it is? Guess I'll have to suck on a few vacuum lines and find out.
    James
    A20A1's Avatar
    Sep 2001
    2006 Chevy Cobalt LS
    if you look on the vacuum line removal how-to and on the sticker that is on the underside of your hood you can get a diagram for how the thermovalves should be hooked up.
    LX User DanG86LX's Avatar
    Jun 2002
    86 Accord LX, carb, AT
    Edmonton, Alberta
    What u're after:
    1. "Heat riser" which is coolant passages at the base of carb.
    2. "Intake air control" door + diaphragm which controls cold/hot air in the snorkel, before air filter.
    Feb 2003
    '86 Accord LX
    Kelowna, BC
    Sorry, #2. I wanna hook up the hot air control again. I don't have one of those stickers under my hood. Anyone have a big picture of one? (for an 86 of course)
    James
    Jun 2002
    Edmonton, Alberta
    For #2, download Paul's manual chap. 11 page 5..7 and look for KX or KQ diagram (86 BS engine only).
    The "Intake air control" is quite simple system:
    [intake manifold vacuum]->#8->[3ways check valve]->diaphragm
    [3ways check valve]->Thermo Switch
    The Thermo Switch is inside black air box passenger side, it air bleeds the system above ~25*C.
    All vacuum lines are routed under air box.
  1. Replies: 19
    Last Post: 05-05-2012, 02:35 PM
  2. Heat Control Problems
    By bank2me in forum 3geez Accords
    Last Post: 10-14-2008, 11:46 AM
  3. Heat riser control diaphram supposed to hold vac?
    By jaiden in forum Carburetor Tech
    Last Post: 01-21-2005, 11:24 AM
  4. Need Better Heat
    By BIGEEZ in forum Classic Honda Community Chat
    Last Post: 12-02-2003, 08:47 PM
  5. NO heat, NO A/C
    By markmdz89hatch in forum 3geez Accords
    Last Post: 12-04-2002, 06:34 AM
