Results 1 to 24 of 24
Thread: Adjustable Fuel pressure regulator
    10/Honda/Ridgeline
    NJ
    Sabz5150's Avatar
    1989 Accord SE-i coupe
    Richmond, VA
    http://www.optauto.com/webstore/prod...ck=yes&dept=93
    This is the ticket. Ya might have to copy and paste the entire link for it to work (Curse Active Server Crap!)
    glorious!
    1988starter
    Guest
    I know you can get on off ebay just type in 89 accord in the search and you should find one from cosmo racing
    10/Honda/Ridgeline
    NJ
    i am not a Ebay fan and i do not have the luxury of time to bid and wait.
    Sabz if thats the answer to my question, then im ordering it now. Tell me it works and its really true, then i am gettin it.
    Sabz5150's Avatar
    Richmond, VA
    Hope this answers all
    (GOOD GOD my engine was dirty)
    glorious!
    LX User G Man89's Avatar
    89 Accord SE-i
    Ohio
    I got a Cosmo Racing adjustable fuel pressure regulator. It works nice and it comes with a guage already installed.
    Heres the link for it. http://www.cosmoracing.com/productin...?cid=96&pid=71
    Hope that helps.
    Go in search of virgin pavement.
    10/Honda/Ridgeline
    NJ
    what kinda gauges are those? Can i use a generic or universal one from summit or something? I also need a AF gauge right?
    1988starter
    Guest
    Oct 2002
    86 LUUUDE
    Kelowna BC Canada
    do we need a FPR made for our cars or can i buy say a, B&M one for a crx and bolt it on?
    Oct 2002
    86 LUUUDE
    Kelowna BC Canada
    i basically want to know what ones are interchangeable because i don't want to have to buy one off the net.. but what ones will work with our motors so i can go about buying one
    Sabz5150's Avatar
    Richmond, VA
    The Cosmo one will work. As will the Vortech. You'll need a seperate gauge for the Vortech though. If you've got a fuel pressure gauge installed already, them that's not much of an issue.
    The B&M fuel pressure gauge will bolt on directly with no modifications. Just look for the one that fits an NSX.
    Here's a pic of the B&M installed.
    The rest of the maze there are the NPT fittings, isolator and high pressure tubing for the Autometer gauge on my dash.
    If you run internal, don't forget the isolator!
    glorious!
    87 Lxi Hatch<-Blown Up!! 96 civic coupe
    Hot, Sweaty Florida
    you really dont need to up fuel pressure unless you have internals or NO2!!! Stock computers run enough for minor bolt ons!!
    Cold Air intake, Apexi N1 turbomuffler w/2.25 piping, H22 injectors,gutted cat, Dc sport header, accel coil, MSD ignition, Dropzone coilovers
    Oct 2002
    86 LUUUDE
    Kelowna BC Canada
    yeah but see i am not scared if my gas milage goes down a bit, i have heard that uppping the fuel pressure will produce decent gains overall. the nsx one will bolt on? i don;t plan on running the guage up at my dash, so if i bought the kit for the nsx FPR i should be good to go
    Oct 2002
    86 LUUUDE
    Kelowna BC Canada
    sorry guys, i know nothing about hp, and engine development.. i am learning thanks to you, suspension and handling are really my thing, i am just looking for some cheaper upgrades to produce more hp in my lude for autocross, but i am not looking to run 14's in the 1/4 by no means
    Sabz5150's Avatar
    Richmond, VA
    Not the NSX regulator, just the gauge. They use the same bolt size for the fuel fitting so they're interchangable.
    For the regulators, the Cosmo or the Vortech will work. The only thing I don't like about the Cosmo is that is has that god-awful long hose running from the rail to the regulator. The Vortech uses the stock regulator bottom, so it sits right where it's supposed to. Just my personal opinion though.
    You might pull a tiny bit of extra power out of your car by upping the pressure a tad to compensate for bolt-ons. Don't go insane with it or you'll lose power and waste fuel.
    glorious!
    LX User jonrichert's Avatar
    Aug 2003
    1987 Accord EF Extra(rhd) A18A
    Summerland, BC Canada
    mugenprelude86
    3geez Newbie
    Vehicle: 86 LUUUDE
    Joined 3geez in: Oct 2002
    hey mugenprelude 86, good to see another k-town member
    Oct 2002
    86 LUUUDE
    Kelowna BC Canada
    hey buddy what do you drive?? i know like ALLLL the accords in town cause i LOVE them.... i have actually been here for along time, i just rarely post.. and what your saying is i HAVE to get either cosmo or vortech fpr
    10/Honda/Ridgeline
    NJ
    okay i got the B&M regulator and pressure gauge. I have a CAI and full exhaust. So what psi should i set it to? 40psi? cause they said u gotta up the pressure for mods and also how on gods name do u fit the regulator on the stock bottom?
    Sabz5150's Avatar
    Richmond, VA
    That's easy. Hacksaw the top off. Leave about an eigth inch of a lip. The instructions should detail the rest. If ya didn't get instructions, I'll give ya a step by step walkthrough.
    I have mine set to about 42PSI. Car seems very happy with it.
    glorious!
    10/Honda/Ridgeline
    NJ
    cool thanks, ill do it
    10/Honda/Ridgeline
    NJ
    well i finally got time to install it last night. I set up the pressure at 40psi to be on the safter side even tho its only 2 psi more than what the stock is. i might boost it up a lil bit once i get better fuel injectors and maybe a rail i dont know.
    Believe it or not, the setting before with just the high volume pump, i was putting out a lil over 55psi. NO wonder my car was running like shit.
    also i found out that my number 1 cylinder spark plug was loose as hell. Now my car runs much smoother and the gas milage and respnose seem to have improved. My next change is gonna be the spark plugs and, cap and rotor and hopefully get an ignition coil.
    Mike's89AccordLX's Avatar
    Mankato, Minnesota
    Hey guys I know you're all FI, but I thought I read somewhere that Carbed guys could have a FPR. I actually bought a Cosmo FPR off ebay for my 91 Prelude Si and well I was wondering if I could use that on my 89 Accord LX. It has the gauge and everything. I'd search but the search thing on the site isn't working and I was hoping one of you knew about this.
    Thanks,
    Mike
    SEi User toastyghost's Avatar
    Mar 2002
    a 93 z34 that's getting parted out, an 86 accord lx that now lives in a j/y, and a 90 camry le that the state no longer allows me to drive. soon to be replaced with an aprilia rs50 or a derbi gpr.
    Harrisonburg VA
    Originally posted by Sabz5150
    [url](Curse Active Server Crap!)
    speaking for my fellow web developers, we resent that remark... :p
    ~<+045+ygH05+>~
    10/Honda/Ridgeline
    NJ
    Thanks,
    Mike
    I doubt you need one cause of the return line is much straighter than out EFI system. So i dont think u would need it let alone i have never seen anyone have it. So i guess its not purposeful to have one.
  1. Adjustable Fuel Pressure Regulator
    By SILENT in forum Carburetor Tech
    Last Post: 04-22-2009, 07:50 PM
  2. [Engine & Transmission] How to install an adjustable fuel pressure regulator
    By Pico in forum How To
    Last Post: 01-02-2008, 05:04 PM
  3. ATTN: anybody with an adjustable feul pressure regulator
    By rallyeNate in forum 3geez Accords
    Last Post: 12-24-2005, 10:22 PM
  4. Adjustable Fuel Pressure Regulator Help
    By Site in forum Carburetor Tech
    Last Post: 07-13-2003, 05:28 PM
  5. adjustable fuel pressure regulator
    By BOLINKXR-89LXI in forum Performance
    Last Post: 03-27-2003, 06:26 AM
