Results 1 to 9 of 9
Thread: switching from 100mm to 114mm bolt pattern
    Nov 2003
    88 2 dr. coupe
    I recently bought a 88 2dr. coupe with 59,000 original miles. It has the 13" factory alloy wheels with the black center. I'd like to up the wheel size, but with the 100mm pattern I think that limits me to a 14 x 6 factory wheel. Is there a way to swap out the front rotors/hubs and rear drum/hubs to the 114mm size from a 90 and up Accord? That would enable me to use a 15" factory wheel. Or is there a way to swap out the above parts to the newer 5 lug pattern? Which would enable me use the 16" or even 17" factory wheel. There is plenty of newer Accords in a local wrecking yard, with the factory rear discs, and related parts to do the swap (master cylinder, lines etc...). Any help would be much appreciated if anyone has attempted this swap. I could always go to the aftermarket but would prefer factory stuff. Thanks for any input.
    nuter
    shepherd79's Avatar
    Falling Waters, WV USA
    why don't you use 2002 civic wheels. they are 16" and they are alloy. plus they are 4x100
    NXRacer's Avatar
    86 LXi Hatch
    Tri-Cities, WA
    there are plenty of wheels that are 4x100 that will fit
    Nothin' 2 Old Racing
    k-roy's Avatar
    87 LX
    Welcome to the board man
    I don't think anyone has ever done it. It would be a lot of work for little payoff. One thing is the hole in the spindels. It is bigger on the newer models so on top of fitting the spindles you would need custom axles. Civic wheels will work just fine.
    As for rear discs you can swap them form a 88 or 89 Accord SEi. The rear discs are the same as a 2nd gen integra. The discs and calipers are the same, but you will need some suspension pieces from the SEi. Check out the howto section, the brake swap is listed there.
    Nov 2003
    88 2 dr. coupe
    Shepard79
    Do you have any pics of the 02 Civic wheels? thanks for the tip.
    nuter
    k-roy's Avatar
    87 LX
    These are all going for $400-$450 a set on ebay. Do a serch for OE Civic Wheels.
    I personally like the third one.
    Nov 2003
    88 2 dr. coupe
    thanks kroy, heading to ebay right now to peer around.
    nuter
    1987 Hatchback phreak project
    NORTH BAY ONTARIO
    all of these bolt on...
    1)
    2)
    3)
    (the ones on the front of the black teg)
    these are all factory wheels... plus there are the new Civic split spoke 5 spokes...
    Travis
    1=Civic SI wheels
    2=GSR Blades
    3=GSR Fat Five's
    87 prelude si A20a3
    michigan
    Yeah we have the same bolt pattern as the 88-91 civics/crxs.....bla bla bla. There is a long list of wheels that will bolt to our hubs.
    -David
    87 prelude si
    87 non-turbo supra
  1. switch from 100mm bolt wheels to 115mm
    By PeterNtheWolf in forum Suspension/Wheels/Tires/Brakes
    Last Post: 11-21-2010, 06:18 PM
  2. Bolt Pattern for Head
    By mynizzle209 in forum 3geez Accords
    Last Post: 03-11-2005, 07:52 PM
  3. bolt pattern
    By 89accordex in forum Suspension/Wheels/Tires/Brakes
    Last Post: 01-29-2004, 11:27 AM
  4. What is my bolt pattern
    By Magny in forum Suspension/Wheels/Tires/Brakes
    Last Post: 12-24-2003, 04:58 AM
  5. bolt pattern
    By 92 ex-r in forum Classic Honda Community Chat
    Last Post: 05-18-2003, 09:36 PM
