Results 1 to 10 of 10
Thread: Wont Start
    Nov 2003
    89 Honda Accord LX
    Santa Cruz, CA
    Angry Wont Start
    I have no idea what to do now, my car sputtered and died on me the other day, it had done this once before but I just started the car back up, it took a while but it started again, and every once in a while the rpms would drop at a stop but that hadnt happened for a while, now it wont start, it tries to and sputters but wont fire up, I replaced the fuel filters, plugs, wires, cap, rotor, and coil but still nothing, I even tried unhooking the fuel pump in the engine compartment and turned the key to the on position and a little squirt of gas came away and thats it.......any ideas why it wont start?
    A20A1's Avatar
    Sep 2001
    2006 Chevy Cobalt LS
    HUH? the fuel pump is in the gas tank...
    You mean the fuel line...
    When you first turn the key the pump primes the carb by squirting a little fuel up the line. After that the engine needs to be running for the pump to work. You maight have a problem with the:
    - Starter Switch
    - Loose battery or gorund wires
    - Distributor
    - Ignition fuel cut-off solenoid at the back of the carb.
    - Fuel pump
    - Vacuum leak
    or maybe
    - Primary booster venturi is totally loose
    Nov 2003
    89 Honda Accord LX
    Santa Cruz, CA
    I took the distributor cap off and there was red dust everywhere, I saw on here that thats a sign of your distributor going bad.
    Nov 2003
    89 Honda Accord LX
    Santa Cruz, CA
    okay I have tested for spark and its getting spark, I installed new plugs and they look like they have fired by the black stuff on the tip, pulled a spark plug and restd it o metal and it sparks, sprayed starter fluid in the carb and still nothing, and you can smell the gas......when I pump the gas gas shoots in the carb so its not a problem with gas or spark, but it still wont start, it cranks but thats about it........I have no idea what it could be.....help anyone....thanks........
    Sep 2003
    1988 Honda Accord LX
    Ajax, Ontario
    something has 2 be clogged....
    Nov 2002
    1988 4Dr Accord LX-Burgandy
    Winnipeg, Canada
    Is the distributor turning? We had this problem once on a Civic and it turned out to be the timing belt. It had lost some teeth and as a result was not turning. Since the cam is the drive for the distributor, and the cam was not turning, neither was the distributor.
    A20A1's Avatar
    Sep 2001
    Check this out while you are at it.
    https://www.3geez.com/showthread.php?...tator+reluctor
    Banned cruznz's Avatar
    Jun 2002
    86 2.0Si JDM DOHC Accord
    checked your earth connections?
    Nov 2003
    89 Honda Accord LX
    Santa Cruz, CA
    Angry
    Yeah the rotor turns, it has spark and fuel.....so I have no idea what it could be
    Nov 2003
    89 Honda Accord LX
    Santa Cruz, CA
    okay I am an idiot, I was looking in the book and I looked at the wiring for a DOHC motor and my car is obviously not a DOHC, its a SOHC and when I put in the ignition control module it wouldnt fire up, changed the wires and gave it some gas and it fired right up......so if your car dies on you and acts like it ran out of gas......the ignition control module is a common cause from what I have been told, go to pick and pull....they are in the "pocket" section and pop that thing in and there ya go, if anyone has any questions about how to remove the ignition control module ask me, I am a pro now after doing it 10 damn times.....thanks everyone.
  1. exi wont start
    By beran24 in forum EFI Tech
    Last Post: 11-26-2009, 05:27 AM
  2. 86 accord start then died then wont start again
    By khmerproduction in forum 3geez Accords
    Last Post: 02-03-2006, 08:07 AM
  3. 87 LX-i wont start...need help
    By whyterice in forum 3geez Accords
    Last Post: 02-08-2004, 09:20 PM
  4. Car wont start after i wen out of GAS
    By LeXUS_ in forum 3geez Accords
    Last Post: 07-05-2003, 02:48 PM
  5. Car wont start after i wen out of GAS
    By LeXUS_ in forum Classic Honda Community Chat
    Last Post: 07-04-2003, 02:50 PM
