Had to take the splash shield off to verify that the radiator is leaking. So, I have left the thing off because I don't want to mess with putting all the little bolts back into it until I get my warranty replacement radiator.
Anyway, now I can see that with my new P/S rack I still have a leak in the P/S pump shaft seal. Local Honda mechanic says it's easy to replace and says I should do it myself. Anyone here ever do that? In the shop manual it just looks like you take out the center bolt in the pulley, remove the pulley, and replace the seal. Do you pry it out? Do you need anything special to put the new seal in?
Other question. I noticed while reading through the P/S section in the manual that the reservoir has a filter built in and you are supposed to replace it any time the system is drained or opened up. I would say that replacing the rack qualifies as "opening" the system. Has anyone else here replaced a reservoir for this reason. Majestic sells them for $43. Is it available aftermarket?
A lot of questions, I know. But, this is where the REAL 3g experts are, after all.
