Results 1 to 4 of 4
Thread: Oil Pressure Gauge
    damnthesenames
    Guest
    Oil Pressure Gauge
    I already did a serach, however I did not find the ansewr to my question. I just bought an 89 LX-i and am looking at putting an oil pressure, among many other gauges in... are there any write up's on how to do so?
    Thanks,
    _ Justin
    A20A1's Avatar
    Sep 2001
    2006 Chevy Cobalt LS
    Closest I could find
    https://www.3geez.com/showthread.php?s=&threadid=12361
    Basicly the Oil pressure sensor or the oil line will hook up to the same port that the old sensor connects to... If it's electrical you migh be able to use the stock sensor.
    The mechanical one will need teflon tape and the adapter fittings to mate the pressure line from the guage to the port.
    damnthesenames
    Guest
    Another question, what is the pressure supposed to be? I know its going to vary, but within what range? my I6 Supra is anywhere from 20-40, what should I be expecting here?
    _ Justin
    A20A1's Avatar
    Sep 2001
    well I get up to 75 - 80 psi 3,000 rpm and it goes up a little from there. I'm not sure what it is at idle... I think normally it's 55 - 65 psi at 3,000 rpm.
    My head gasket bleeds oil some... but I check the oil level constantly and there is not even a noticable drop.
  1. Installing Oil Pressure gauge..
    By Tdurr in forum 3geez Accords
    Last Post: 04-29-2008, 06:42 PM
  2. New Oil Pressure Gauge
    By damnthesenames in forum 3geez Accords
    Last Post: 03-02-2004, 01:54 PM
  3. FS: B&M Fuel Pressure Gauge
    By anchovies in forum Trading Post
    Last Post: 09-14-2003, 10:06 PM
  4. Fuel Pressure Gauge?
    By colinnicholson86 in forum Carburetor Tech
    Last Post: 06-29-2003, 04:48 PM
  5. B&M fuel pressure gauge
    Last Post: 05-27-2003, 10:36 AM
