Has anyone figured out a way to remove the clear cover on the taillights without destroying it? it's held in with mastic or something like it. Even if I destroy the cover I can make another one, It's hard to remove the cover without destroying the lenses thats all. Someone said you can heat it to losen the mastic. has anyone tried this? If I can get the cover off I have some taillight ideas I'm expermenting on a broken taillight now, no luck so far. Ok here's the idea, i have a light I'm testing this on, I removed the clear lens from the reverse light, then I made a stepped plate that fits in place of the clear lens. I found a set of micro driving lamps, the projector kind with the convex lens, I will drill a 1.350" hole in the plate then epoxy the lamp to the back of it so just the lens is showing. The plate will also be powdercoated black to match the housing trim. Then I remove the reverse lamp reflector so everything will fit. the effect this will have is to make the reverse lamps almost disappear. yet when they are on they will actually do something. These lamps are only 20 watts so heat shouldn't be a problem. i belive I will just make a new clear cover, thus getting rid of the ugly reflector in the middle of it. I have an idea for the indent in the lens but more on that later. here are some pictures.
.......... this is one view of the plate. ..........
......... here is another view of the plate, it's actually two plates heliarced together.
.......... heres the lens with plate OK START OVER NEW IDEAS BELOW
