Results 1 to 7 of 7
Thread: HU removal
    SEi User 89accord_lxi_coupe's Avatar
    Jan 2003
    Louisville, TN
    HU removal
    ok, what i have now is a sony POS HU. a friend of mine is willing to give me his Kenwood HU, it's a definite upgrade from what i have. i have been told that it's not necessary to remove any of the dash the remove and replace the HU. yes it does have a wire harness kit, otherwise i wouldn't have the sony in it. from what i read in another post, you remove the ashtray and another piece holding it in. then you unhook the wires from the rear of the HU and slide it out. have i got it so far? when i went to look in behind the center console and my HU it was difficult to maneuver so i could see well. is that just something i will have to put up with to get this done? if i missed any steps or you have a quicker and more efficient suggestion, let me know. TIA
    Nolan
    check my profile
    I'm on AIM at Maxaccord3G
    I AM THE STIG
    Vinny's Avatar
    Aug 2003
    Here, not there
    heres everything ya need to know with picturesinstallDR.com Its in PDF format so it may be slow to load.
    Jan 2003
    Louisville, TN
    thanks for linking that, but i'm not removing a stock deck. i'm taking out an aftermarket sony HU. will i just basically have to disconnect the cables and pull it out?? that does give me an idea what all will be involved, but not how i actually unhook it. i hope i'm making sense.
    Nolan
    check my profile
    I AM THE STIG
    Vinny's Avatar
    Aug 2003
    Here, not there
    SOMETHING is holding the radio in, most aftermarket head units have a mounting sleeve that they slide into. They usually slide in and lock into place to secure it. It may need some sort of key to unlock the radio from the sleeve. I'd work on sliding the HU out first. once you get it unlocked from the sleeve you should be able to pull it out and disconnect the harness. If not then you may have to reach in from behind to disconnect it
    SEi User BMS's Avatar
    Nov 2002
    88 LX / 97 Teg
    California
    I had to reach in from behind on mine, the stock harness wasn't long enough to reach the back of my new deck while outside.
    You'll probably have to use a flathead screwdriver and pry it out. There are little fins on Sony's that lock the unit in. You have to find them and depress them. Be careful not to booger up your dash around it while removing it.
    blazin3gen's Avatar
    Good Ol Cali
    there is like two clips holding it in place to the left of the deck and to the right of the deck with a flat head u can pry it out
  1. EGR removal
    By import racer in forum EFI Tech
    Last Post: 09-10-2009, 07:52 PM
  2. P.S removal
    By Rendon LX-i in forum Suspension/Wheels/Tires/Brakes
    Last Post: 06-02-2009, 09:00 PM
  3. Oil Pan removal
    By helmut in forum 3geez Accords
    Last Post: 05-12-2009, 02:15 PM
  4. a/c removal
    Last Post: 09-20-2008, 05:31 PM
  5. Inner tie rod removal
    By Sabz5150 in forum 3geez Accords
    Last Post: 08-04-2003, 09:22 AM
