Results 1 to 4 of 4
Thread: coil overs
    Jun 2002
    1987 LX-i hatch
    houston,TX,USA
    Exclamation coil overs
    does anyone know if coil overs for a 97 civic will fit my 87 LX-i. I hope so cos I'm gettin a sweet deal.
    GDGuy11B's Avatar
    Jul 2001
    1989 Accord LX-i, 00 Civic EX
    Back from Baghdad (Tallahassee)
    not sure...but thats what e-bay is for
    89 Silverstone Metallic LXi, custom Air Intake, DC Sports 4-2-1 header, A'PEXi N1 exhaust with 2.25" pipe, ACT clutch, Xenon body kit
    3geez member since July 11, 2001
    Jun 2002
    1987 LX-i hatch
    houston,TX,USA
    does anyone have a REAL reply:flipa:
    86 Honda Accord LXI HB 5-sp
    Central California
    FYI, you posted this question in the wrong section of the board, one of the other moderator's moved to where it belongs for me.
    You question hasn't been answer because NO one has done this, so one can give you the answer your looking for. However as long as you can use the very top section from your car with it's three bolt mounting or the entire top half, you should have no problem. Now it is possible that if the 96-2000 civic is a car with greater suspension travel, you may have to cut the threaded coilover part a bit so it will fit. Then again, you might not have to worry about that, because some coil-over kits don't aren't designed to give full suspension travel.
    I'm curious what product are you looking to buy, and how much?
    Now I d
  1. full bodied coil overs vs coil over sleeves
    By newaccorddriver in forum Suspension/Wheels/Tires/Brakes
    Last Post: 06-19-2007, 11:54 AM
  2. full bodied coil overs vs coil over sleeves
    By newaccorddriver in forum Classic Honda Community Chat
    Last Post: 06-17-2007, 11:57 PM
  3. Full Coil-overs. Why not?!?!
    By w00tw00t111 in forum Suspension/Wheels/Tires/Brakes
    Last Post: 06-29-2005, 09:21 AM
  4. Need Coil Overs !!!!
    By zerotap in forum Suspension/Wheels/Tires/Brakes
    Last Post: 02-03-2004, 05:12 PM
  5. coil overs
    By hoho1217 in forum Suspension/Wheels/Tires/Brakes
    Last Post: 01-13-2003, 12:23 AM
VigLink badge
