Results 1 to 6 of 6
Thread: Got a brand new power antenna assembly!!!
    Mike's89AccordLX's Avatar
    Mankato, Minnesota
    Well I have never had my power antenna working and well I found a new one on ebay and bought it. It was like $9.99 so I could pass it up. The thing is brand new and perfect. Only bad thing is I forgot my Service Manual, Haynes, and my Chiltons at school. So I don't know how to take the dash apart. I have big hands so I can't do stick your hand up under the dash and put it in. I haven't done this and I don't know how. Should I just wait until I get my manuals from school or will you guys be able to help me enough?
    There's a red wire and a green wire coming from the antenna motor. And then there's the antenna plug-in that you put in the back of your Stereo HU. I'm just assuming that the red and green wires hook up with my switch somewhere. Does anyone have pics of what I need to take the dash off? This will be good b/c I have 6" light bar I have been wanting to put inside the gauge cluster.
    Thanks for your help guys.
    -Mike
    NXRacer's Avatar
    86 LXi Hatch
    Tri-Cities, WA
    thats a good question. mine doesnt work well either but i never bothered because i've heard they are a royal pain in the ass to replace.
    Nothin' 2 Old Racing
    Mankato, Minnesota
    Yeah I've heard that too, I know you have to take the whole dash off so yeah it's gonna be a beatch. I think I will have to wait b/c I forgot most of my tools at school, but if you guys can still help me I'm sure I can borrow my brothers sockets.
    -Mike
    PhydeauX's Avatar
    Eastern Penna
    I managed to change mine (gen2, non-power, but still may apply) only taking the lower part of the dash off. The trick I used was to tie a length of wire to the end of the antena cable, then pull the old antena out. I then tied the wire to the new antena and fished it back in with that. Saves alot of headaches. I tied the knot before I even pull the cable out from the radio area and wraped it with tape so there would be no loose ends to catch on things. The only reason I even had to take the lower dash apart was it would get caught up in some of hte other wires and I had to work it free.
    andy
    Jareds 89 LX-i's Avatar
    Apr 2001
    Black '89 Accord LX-i sedan
    Mills River, NC
    You don't have to take the dash off at all.... just drop the fuse box down (two 10mm nuts) and you'll be able to get at it much easier. I pulled two of them at the junkyard, and after you figure out how to get at it it's really not that hard at all (the second one I pulled I had out in less than 10 minutes)
    There's a little "C" clip that connects the antenna mast to the motor (DON'T LOSE IT.... it springs out of sight rather easily). You have to take that out in order to separate the two (otherwise you'll never get the mast out the top). Then it's just the electrical plug and I think 2 10mm bolts/nuts and the motor comes right out. You may want to take a piece of string and tie it to the old antenna (bottom, by the motor) before removing the old one from the pilllar. Then when you pull the old one out it will bring the string up with it, and you can tie that to the cable part of the new one to guide it down the pillar to the exact spot the old one came out of.
    -Jared
    Mankato, Minnesota
    Alright that sounds fairly easy I will take out that fuse box thing tomorrow and take a look at it. Thanks for your help. Any other advise would be appreciated.
  1. Power Antenna @ JY
    By King Peetis in forum EFI Tech
    Last Post: 12-31-2012, 07:53 PM
  2. power antenna
    By accordfan in forum Classic Honda Community Chat
    Last Post: 12-26-2012, 10:13 PM
  3. power antenna again
    By mboardman in forum Interior & Exterior Care
    Last Post: 10-03-2007, 11:29 PM
  4. Power antenna v. manual antenna masts
    By offthahook in forum 3geez Accords
    Last Post: 09-08-2002, 03:53 AM
  5. Power antenna
    By brianc85 in forum 3geez Accords
    Last Post: 06-25-2002, 12:54 PM
