Results 1 to 3 of 3
Thread: transmission doing wierd things
    Dec 2003
    The auto transmission in my 89' honda accord does some pretty wierd things. When i first start it up, before everything gets nice and warmed up, it doesn't want to shift right. If i put it in D3 or D4, then it will just stsay in first. If i put it in "2", it will stay in 2nd, then if i try to slip it to D3 it will just go into neutral. Then once everything gets warmed up a bit, everything works properly. Not that big of a deal, just have to let it warm up a bit before i leave if i plan on doing any higher speed driving. But why is it doing this? Will it get worse if i just ignore it?
    Justin86's Avatar
    Medford, Oregon
    Well check you oil level and it most likely needs to be changed. It could be the incorrect oil weight and that is why you have probs at low temps. Well at least you can still drive your car mine has been down for a month.
    A20A1's Avatar
    Sep 2001
    2006 Chevy Cobalt LS
    hmm well if it wasn't dependant on temp then I would have said it was a Throttle-Value cable problem.
  1. wierd things
    By wallacefan in forum EFI Tech
    Last Post: 03-05-2008, 08:06 PM
  2. Wierd transmission shifting
    By Slanter in forum 3geez Accords
    Last Post: 09-04-2003, 08:33 PM
  3. Wierd transmission shifting
    By Slanter in forum Classic Honda Community Chat
    Last Post: 09-03-2003, 02:54 PM
  4. brakes....wierd...just plain wierd....
    By Microstreak in forum 3geez Accords
    Last Post: 03-27-2003, 01:14 PM
  5. Hey transmission wierd noises
    By 87blueaccorddx in forum 3geez Accords
    Last Post: 10-15-2002, 08:42 PM
