I had the engine running and took of some of the vacuum lines, to check for leaks, but all was fine and engine is still running fine. I remembered that i had to check my clutch cable so turned of the engine and i removed the cable and checked it. Fine too. Then when I try to turn the engine back on, it wont start... It reacts a little once in a while but doesnt get going. Then I tried spraying in some cold-start(?) spray. This gets it going but only a couple of seconds. I'm thinking that maybe it doesnt get any fuel?? Could I have jacked off some wires or something while removing the clutch cable? I checked too see that all vacuum lines are connected and they are. I tried resetting the ECU, and removing ground terminal for the battery a couple of minutes. What the hell can be wrong??
