Results 1 to 5 of 5
Thread: Head Removal
    damnthesenames
    Guest
    Head Removal
    I'm not trying to repost, but the searches are down at the moment. Is there a thread or a write up of removing the head? What all needs to be done/taken off so on? I just spent about 10 minutes looking over the engine bay and decited i'd like to read about someone else doing it first...
    Thanks
    _ Justin
    LX User it's paid for's Avatar
    Sep 2003
    '83 Accord and yeah, I know it's a 2G okay?
    AL border in GA
    Mine's off right now . . . I'm sure I'm leaving off something, but this is how mine worked out . . .
    • put it up on ramps
    • drain engine oil & coolant
    • remove battery
    • label & then disconnect spark plug wires
    • spin engine to TDC at #1 (use timing marks at crankcase
      opening mine takes a 17mm - spin it counter-clockwise)
    • mark position & then remove distributor
    • remove a/c pump (or whatever it is) and two engine mounting bolts near #1 cylinder
    • remove power steering pump
    • remove alternator (I had to replace mine)
    • remove all belts from crankshaft pulley (mine had 3)
    • remove crankshaft pulley nut (what a chore!)
    • remove valve cover
    • remove timing belt covers (mine has upper/lower)
    • detach relevant coolant hoses
    • detach relevant electrical wiring and connectors (ground to valve cover, et cetera)
    • remove (or cut off) timing belt
    • disconnect exhaust manifold at downtube
    • disconnect exhaust manifold support at engine block
    • disconnect metal tube going from exhaust manifold to intake manifold
    • remove cam-driven gear & shaft for oil pump
    • remove carburetor (first remove the air filter cover, et cetera)
    • remove head bolts
    • remove head
    • remove intake & exhaust manifolds
    • remove thing at end of head near #4 cylinder
    • take head to shop
      - do not have valve guides knurlled and reinstalled - use new valve guides
      - do not let the engine head slide off the bench onto a concrete floor
    Please keep in mind, I have a 2G w/the EK1 engine & it's a little different than the 3G's . . . also . . .
    1 - mark how belts were installed & reinstall with same orientation
    2 - I use labeled envelopes for the fasteners
    3 - take digital photos to help w/assembly & so forth
    Hopefully, this will help . . . ? . . .
    Justin86's Avatar
    Medford, Oregon
    Well you don't have to remove the crank pulley unless you are changing the timing belt. It will help to know why you are removing the head so I can help you with shortcuts. The list above is everything and a lot of time you don't need to remove all that stuff. I have done it with just removing the exhaust and head bolts and the drain coolant.
    damnthesenames
    Guest
    WHy? HEre's why :)
    I just bought my car... had a broken timming belt, so I had guessed the valves/pistons might be shot. I pulled off the valve cover, undid the rocker arm rod, and did a compression test. My results where somewhere in the range of 30-0-91-0. So I'm going to pull the head off, possiably fix, or possiably replace. That's why Thanks for your help, and any shortcuts you could offer
    Its fuel injected, if that matters any
    Justin86's Avatar
    Medford, Oregon
    Ok I will get some info for you. check your PM
  1. Head removal ???
    Last Post: 03-17-2012, 03:39 PM
  2. HELP!!!!head removal
    By asianimports69 in forum 3geez Accords
    Last Post: 04-29-2004, 01:51 AM
  3. Replies: 31
    Last Post: 12-05-2003, 07:08 AM
  4. Head removal
    By Versanick in forum 3geez Accords
    Last Post: 01-09-2003, 03:23 PM
  5. Cylinder head removal on LXi
    By DevilZ in forum EFI Tech
    Last Post: 12-16-2002, 08:16 PM
