Results 1 to 5 of 5
Thread: flip lights
    Aug 2003
    flip lights
    my flip light stop fliping. i check all the fuse . where is the fuse located.
    shepherd79's Avatar
    Falling Waters, WV USA
    something wrong with your headlight switch. the only way to get it fixed is to replace the hole combo switch.
    2007 pilot
    Lv, nv
    the fuses are under the drivers side kick panel... but i dont recall there being any for just the retractor motors. anyway, there are several things that can cause this. first, do your headlights work even when they are down? if the lights themselves work, then its either your retrator motors, retractor motor main relay, the two seperate retractor relays, or (the easiest one to fix) the little switch thats to the right of the steering wheel; The one that you can press to leave your headlights up when you turn off your lights. if you know electronics well enough, just download pauls manual, and start probing the main unit and wiring harness. When i had this problem, i was able to determine that it was the little switch to the right of the steering wheel. So i replaced it, and viola. If your headlights dont work at all (ie, they dont flip up and theres no light coming from them), then its probably your combo switch or a fuse. check all the fuses under the drivers side panel, and in the engine compartment. good luck.
    SEi User Dibbs's Avatar
    May 2003
    '86 LX-i Hatch
    Houston
    Couldn't have explained it better Rusty. Good Job!
    Quote Originally Posted by kroy
    Mad props to you if you can pull it off, you can change your name to slowassoldschoolswap :thumbdown
    Vinny's Avatar
    Aug 2003
    Here, not there
    like rusty said it could be one of several things.
    Is it just one thats not flipping up or is it both of them?
    Do they flip up with the dash switch or are they not comming up when you turn the headlights on or both.
    If they come up with the dash switch but not with the headlight switch on the column then yes you might have a bad combo switch
    If both of them won't come up with either the dash switch or combo switch you may have a bad ground
    If its just one not comming up check fuse #6 under the hood for the right headlight or fuse #7 for the left. Those 2 fuses power the individual retractor motors.
    Knowing how the system works will help tons in getting the problem resolved, its alot cheaper to troubleshoot it smartly than just throw parts at the car like an idiot
    EDIT Let us know what you find and we'll help you narrow it down a little more if none of these suggestions help ya
  1. Why did we get the flip-up lights?
    By w261w261 in forum Classic Honda Community Chat
    Last Post: 01-03-2010, 02:36 PM
  2. Flip Up Lights
    By AccordRacing21 in forum 3geez Accords
    Last Post: 01-25-2006, 11:21 AM
  3. about the flip up head lights???
    By disfunktional8o8 in forum Interior & Exterior Care
    Last Post: 12-22-2002, 09:05 PM
  4. those darn flip up lights.......
    By Jubei415 in forum Interior & Exterior Care
    Last Post: 10-03-2002, 04:15 PM
  5. moldings for the flip up lights
    By chucknice in forum Classic Honda Pics & Videos
    Last Post: 09-17-2002, 02:58 PM
