Results 1 to 10 of 10
Thread: acceleration
    Dec 2003
    89' accord LXi
    roch, new york
    acceleration
    i have an 89 accord LXi 2.0 fuel injection 12 valve its basicly bone stock i want to hook it up its an auto 4 speed the mid range and top end speeds are ok but acceleration isnt all that good are there any adjustments or simple mods i can do to help off the line
    shepherd79's Avatar
    Falling Waters, WV USA
    nope, you have auto and it is your number one problem.
    you can change the tranny fluid but i don't think it will help much.
    10/Honda/Ridgeline
    NJ
    Re: acceleration
    For the tranny like Alex said, its ur prob. Manual is the way too go. and for performance mods, cehck the performance section
    Your transmission is slow and weak, so that is something you will have to deal with and cannot change unless you swap over to a 5 speed.
    As for things you can do, try changing spark plugs and wires if they have not been done in a while, or if the wires you have are cheap. Good wires are worth it.
    As far as changing the transmission fluid, I wouldn't do it unless you KNOW that it has been maintained. There have been horror stories about autos and changing the fluid in the transmission for the first time in a long time. Basically, the transmission will die within a month. This is because the transmission learns to work with the metal fragments inside of it, and once they are gone, your transmission will not know what do without them.
    LX User it's paid for's Avatar
    Sep 2003
    '83 Accord and yeah, I know it's a 2G okay?
    AL border in GA
    . . . once they are gone, your transmission will not know what do without them.
    Isn't that why they created saw dust?
    Ummm . . . brella, I needanumbrella.
    Hey, be my guest
    A20A1's Avatar
    Sep 2001
    2006 Chevy Cobalt LS
    Lol, saw dust.
    ...you can always powerbrake... or get a modified Torque convertor.
    Accord of the Year - 2008
    TWOLOUDNPROUD's Avatar
    May 2003
    Ok that is somewhat BS if you rebuild the Auto and put a stall converter in @3200rpm it will keep with a 5speed.It is Cheaper to do a 5speed swap then to build Auto.I put $1500 in to my Auto but that was my choice. But remember if you want to build a auto do your motor first then your auto it takes more Hp for a stall converter to work right.
    A20A1's Avatar
    Sep 2001
    was $1500 for a TC or a rebuild?
    May 2003
    475.00 for the stall converter . I had it made in sacramento ,Ca
  1. Hissing at Acceleration between 1-3K RPM
    By Discovery in forum Carburetor Tech
    Last Post: 11-02-2011, 08:55 AM
  2. Rev and Acceleration
    By rideordie12 in forum 2geez Accords
    Last Post: 01-01-2011, 11:54 PM
  3. Car vibrates under acceleration
    By kinabalu in forum 3geez Accords
    Last Post: 06-09-2006, 09:03 AM
  4. acceleration help
    By GDGuy11B in forum Performance
    Last Post: 11-10-2002, 01:26 AM
  5. Acceleration.....
    By 89AccordExi in forum Performance
    Last Post: 07-16-2002, 12:57 PM
VigLink badge
