Results 1 to 25 of 27
Thread: left turns
    Jun 2002
    89 Exi
    Winnipeg Canada
    Question left turns
    i gots a problem...when i make sharp left turns i hear a clunking sound on the front right side....clunk clunk clunk..until the wheel is straight...any ideas what it could be??
    im gonna get it checked out soon i hope....
    Aug 2001
    1988 Accord DX 5spd
    Dayton, OH
    It's your CV joint. If you take it to a shop, they'll rape you to replace it. You can get remanufactured ones from Autozone for about $60. Only problem is installing them yourself.
    LXi User Jerren's Avatar
    Jul 2001
    1991 H23 powered Accord EX Wagon , Turbo 91 Honda CRX, and 96 Blazer LT
    St. Louis
    yah i just got one replaced for $238 parts and labor.
    Oct 2001
    87 Accord EX , 5spd , Manual
    sorry to say ! but the C.V joints are out ! may be not both !
    MIKE
    1988starter
    Guest
    I had that prob and it was a loose part on y caliper rubbing my disk and I just got two new halfshafts 380 installed.
    carotman's Avatar
    Montreal South Shore
    god damn, anything more than 100 bucks is a ripoff....
    I need these parts!
    1988starter
    Guest
    For the half shafts that is new axels cv joints boots well everything from the tranny to the wheel they were 130 for each one.
    88 LX Action
    Podunk, Alabama
    holy crap, ive had that same problem, and never thought twice about it! what effects can happen if i ignore this? will my car break down like old schools? also could this be the cause of intense car shakage whenever i brake? im paranoid now, and dont have the cash to replace it.
    real 3geez http://www.3g-generation.com
    i sold the honda. now working on a car with little bit more potential, an 88 supra. i still stop by occasionally.
    not in the same manner but the bearings will spill out all over the road and you won't be able to drive the car except pushing/pulling it, extracting the remaining chunk of axle/hub will probably be a bitch too
    Eric
    Aug 2001
    1988 Accord DX 5spd
    Dayton, OH
    What is going on inside the joint to make the clunking sound?
    Jun 2002
    89 Exi
    Winnipeg Canada
    damn it sounds pretty bad...but i dont got the cash to spare right now..gotta wait a few more weeks or something...hopefully nothing bad happens till then...
    88 LX Action
    Podunk, Alabama
    how hard are they to install yourself? and does it matter if i replace both, or if only ones making noise can i just replace that one?
    Oct 2001
    some little balls outta of place !!!
    MIKE
    Oct 2001
    not too hard but the nuts are really bitches to remove ! !!
    you need a breaker bar for the spindle nut 32 mm and even with that it may not turn loose ! i used a 2 meters pipe !
    MIKE
    88 LX Action
    Podunk, Alabama
    MIKE
    for what, the hub nut? ive easily gotten that off with a huge scoket before. im looking through the haynes manual, and it isn't too clear on replacing the joint, but i think ill be able to once i get the cash. and if i can somehow get my hands on a prelude arm could i just swap that in, will that fix the cv problem?
    Aug 2001
    1988 Accord DX 5spd
    Dayton, OH
    No, the prelude arm won't help. The CV joints are part of what connects your wheels to your transmission. The control arms just keep the wheel in place, parallel to the ground.
    When I replaced mine, it wouldn't have been very hard but the bolt that connects the lower arm to the fork was seized up. That made it really tough getting the axle out.
    89cordlx's Avatar
    Black 1989 LX-I Coupe and 2000 EX V6 coupe
    Westerville, Ohio
    it cost me 500+ to get both nmy cv shafts and joints replaced (thats parts and labour) I think they ripped me off, but hey my mom payed for it hehe
    Banned cruznz's Avatar
    Jun 2002
    86 2.0Si JDM DOHC Accord
    bloody hell!! prices for parts over there are expensive.
    It's quicker and cheaper to get a good second-hand axle if you r like me with hole in wallet... , if u got the $$$,C.V kits are reasonably easy to put on,remember to drain some tranny fluid out first or you will lose it when u take half-shaft out
    Undo axle nut while the wheel is still on,i've nvr had much prob taking them off
    I've done hundreds of C.V's,once you've pulled 1 apart,you'll be able to do it blindfolded....:smokin: lol
    Oct 2001
    once you get the hub nut out ! it's not difficult !
    anyway i heard on this board before that you can do it without draining the tranny oil !! ?? can some one confirm that !? ?
    MIKE
    Jun 2002
    Yeah,.....you can do it with shaft still in......taking it out just gives you more room to take outer C.V off.......you will need to clamp the shaft some how to stop it from moving as you try to knock the outer C.V off the shaft....and sometimes they can be a bit tight and awkward to get off with shaft still in...up to the individual i s'pose.......C.V should pop off with a good whack with a heavy, soft head hammer......
    Jul 2002
    89accord hatchback DX
    fallbrook
    cv boots
    your pretty much screwed. once your cv boot is torn and your axle is exposed, your axle is screwed, especially if its making such a loud click. good news though, you can usually get a right and left axle at Kragen or Napa (lifetime warranty) for about $150. And they are 10x easier to replace than just the boot. I was able to do both of mine in about 2 hours by myself. Just get one of your mechanic friends to help you and your set.
    Jun 2002
    89 Exi
    Winnipeg Canada
    replaced the cv joints and shaft (brand new) and car feels more sturdy...
    replaced one of the tire rods but guess what...
    when i make turns it still makes that broken clunking sound...but not as baadd..hmmm still not sure...???
    the assembly..suspension..i got no idea...
    Can any one think of what might be causing this??
    Jun 2002
    89 Exi
    Winnipeg Canada
    Thumbs down
    maann...those clunks are botherin me....every sharp turn clunk clunk...and its not the cv joints....shietty dealz
    '89 Honda Accord Lx-I
    St. Charles, MO
    My best friend's dad told me that there was some kind of bolt that needed to be tightened. I don't remember what it is but, i'll ask him tommrow and follow up.
    -Lē
    89cordlx's Avatar
    Westerville, Ohio
    why not take your car to a garage for a free inspection?
  1. fuel problems(no left turns)
    By accord upset in forum 3geez Accords
    Last Post: 07-18-2005, 07:47 PM
  2. Car Turns Off!!
    By rleyba in forum 3geez Accords
    Last Post: 11-16-2004, 01:11 AM
  3. no power on left turns
    By POS carb in forum 3geez Accords
    Last Post: 11-05-2003, 12:47 PM
  4. RPM fluctuates on left turns
    By drknow in forum 3geez Accords
    Last Post: 09-28-2003, 02:57 PM
  5. PGM FI light turns on
    By od2681 in forum 3geez Accords
    Last Post: 01-05-2003, 10:06 PM
