Ok, rota subzeros in 16's are a +40 offset, and the 17's are +45. I emailed www.machiii.net and asked them if that difference would cause rubbing I got this as a reply
"Hi Andrew...
Yes, the off-set will work great for your car...your can can accept an
off-set from 40mm to 45mm
Mike
Mach III
www.machiii.net"
Is that true? Also if I lower my car about 1.5" will it then cause rubbing? Thanks guys
