Several days of nice weather got me to start my project of redoing the paint of my interior. The last owner tried to paint almost all of the trim with white. He did it cheap and quick. There is a lot of chiping and peeling going on.
I pulled one none important piece to use as a practice to make sure my method will work right so I don't have to redo the whole car.
Here is what I have done to it:
1.scraped and sanded all of the old paint off as best I could bringing the factory color to the top.
2.washed it in HOT soapy water
3.wet sanded the minor dings and scratches out of it (320 grit)
4.rewashed
5.3 coats of primer
6.wetsanded (600 grit)
7.2 more coats of primer
8.3 coats paint
9.wetsand (600 grit)
10.2 coats paint
Now do I let this cure as is and re-install, or should I clear coat it to further protect it more. It will be in the sun and is a dark gray so it should attract a lot of heat from the sun. It will also be handled lightly from time to time.
Sorry for the long post.
P.S. I did a clear coat search an found nothing on this topic.
