Results 1 to 7 of 7
Thread: New pcv, turns on ecu error 6
    DX User SrvZro's Avatar
    Nov 2003
    '89 Accord LXi
    So Cal livin'
    I replaced what seems to be the original pcv that came with the car. 89 accord lxi.
    Now my check engine light stays on. Its gives the code 6 COOLANT TEMPERATURE SENSOR.
    I've tried to reset the ECU and it keeps coming back as soon as I turn the car on. Has anyone heard of this before or have any ideas why this happened. I'm going to replace the sensor eventually.
    The check engine light is annoying and I don't want my car running too rich.
    *I also changed the distributor cap and rotor. But it started up w/out problem after I had just changed these two things.
    Any help/ideas are welcome.
    shepherd79's Avatar
    Falling Waters, WV USA
    you can't do anything, but replace the sensor.
    i had the same problem. first it was EGR valve and after that O2 sensor.
    1988starter
    Guest
    did you knock something loose when you installed it.
    Nov 2003
    '89 Accord LXi
    So Cal livin'
    Nope, nothing that I could see. I made sure that the connections were tight for everything.
    I was able to disconnect the hose and pull the whole pcv out by tugging on the hose. This was after I wasn't able to find where the damn thing was. It wasn't until I found the pic in the faq.
    The old pcv was really worthless. There was no spring noise and it was full of gunk. I have a feeling that now my car can breath its finding out all the other problems with it has. *tip of the iceberg*
    1988starter
    Guest
    Quote Originally Posted by SrvZro
    Well just incase check all vacume hoses and reset the ecubthe code may go away I remember when my fuel pump was failing my ecu gave me codes for both the IAC and O2 sensors
    Idaho
    I would just change, they should be cheap anyways.
    Nov 2003
    '89 Accord LXi
    So Cal livin'
    I'm convinced that my car's ECU has a mild case of mental retardation. Because the check engine light was lit on the way to work, then to lunch. But then after lunch the light turned off. Even on the ride home and I stopped at a few places before I got home and no light. I figure that maybe it just took a while for the system to get used to the new pcv? The ECU is a mystery to me, I’m just glad that the light turned off. But I might change the coolant sensor out anyways. Just to be sure. But first I want to get a Accel coil and new NGK plugs.
  1. Here we go again site error
    By TWOLOUDNPROUD in forum 3geez News & Site Feedback
    Last Post: 04-06-2009, 08:47 PM
  2. FAQ's error?
    Last Post: 12-04-2005, 04:01 PM
  3. cant tell which error is it in the ECU
    By 89project in forum 3geez Accords
    Last Post: 11-16-2003, 03:35 PM
  4. Error in FAQ??
    By xbi0s in forum Classic Honda Community Chat
    Last Post: 03-21-2003, 11:04 AM
  5. Error 12, Error 12. She's Gonna Blow
    By Immeraufdemhund in forum 3geez Accords
    Last Post: 03-18-2003, 06:03 AM
