Results 1 to 8 of 8
Thread: Good Prices for LED Bulbs
    Nov 2000
    This site even has an LED version of our dome light (31mm). The shipping charges are pretty low, too.
    http://autolumination.com/
    I ordered myself two inverted clear amber 194's for my front corner lights and a dome light. I'll let you know how they work. I have a set of amber APC LED's in the corner lights now, but they are "focused" an pretty much hit one spot - still looks more interesting than the stock bulbs, though.
    Peace.
    Justin86's Avatar
    Medford, Oregon
    well that is pretty cool but we need to get this moved to the APPERANCE sec.
    nice, it's about time someone started making all those bulbs in LED, I've been trying to make my own for over 2 months already
    Eric
    Nov 2000
    One of the drawacks of an LED inplace of a bulb, as I found out when replacing the D4 indicator with an LED, is that LED's do not dim. As long as you are exceeding the forward voltage (which is about 4 volts) they are bright.
    So you need to use them where they are not going to need to be dimmed. Also, they can cause issues in turn signals or brake lights as they use so little power the brake light sensors or turn signal flasher will "think" you have a burned out bulb. I saw online several places to buy balancing resistors to take care of that.
    Sabz5150's Avatar
    1989 Accord SE-i coupe
    Richmond, VA
    www.superbrightleds.com
    They sell *EVERYTHING* LED at great prices. I got my tri-colors from them for my RGB project. Speaking of which....
    glorious!
    2.0Si User buzzbomber88lx's Avatar
    1985 Toyota Celica GT, 86 accord lx-i, 89 supra turbo
    Kansas
    yes this does need moved. i am gonna order a crap load of those 194 bulbs and some 1157's.
    1985 toyota celica 3sgte project
    1989 toyota supra turbo
    1986 honda accord 4dr lx-i
    Nov 2000
    It looks like the selection and pricing is about the same as at the web site I posted. I wish I had found this BEFORE I replaced all the bulbs in my instrument cluster!
    For now I am just going to replace selected bulbs with LED's.
    Nov 2000
    As I mentioned before, the LED bulbs may not be good to use as backlighting in the instrument cluster. You cannot dim them with the standard dimmer so if you think they are too bright you would be stuck with that. For example, now that my D4 indicator is lit with an LED it stays the same brightness with the lights on or off. Normally, the shift indicator bulbs dim when you turn on the lights.
  1. 100 Watt Bulbs, Good Results
    By HondaBoy in forum 3geez Accords
    Last Post: 06-11-2004, 11:23 PM
  2. Best Prices On PIAA Bulbs
    By HondaBoy in forum Trading Post
    Last Post: 11-27-2003, 09:14 PM
  3. tires wareing down, good prices rims
    By PogiLXI in forum Suspension/Wheels/Tires/Brakes
    Last Post: 04-22-2003, 09:50 AM
  4. Good info on Headlight bulbs
    By OldSchoolSwap in forum Performance
    Last Post: 07-15-2002, 03:40 PM
