What OBD-0 distributors have the crank angle sensor built in? Specifically electronic advance. If there's a 3g Prelude distributor that has it, so much the better
i am not sure about OBD-0.
i know there is accord with 4g distributor conversion. do the search on the board.
i emailed the guy and told me it is too complicated to do.
nah, the 3g prelude crank sensor is separate from the distributor... same for the Accord B20A engine (that's the part on the exhaust cam)
The 90-91 Integra with the PR-4 ECU (OBD0) has everything inside 1 distributor if that's what you want!
I need these parts!
I located a PR4 distributor, so I'm gonna start researching what I need to make this work. I'm gonna try to adapt the A20 to use electronic advance with either a PK2 or PR4 ecu. While not as elegant as Sean's setup, it will allow for more tuning than stock at a cheaper price.
Any suggestions or ideas are welcome
Are those Prelude SI ECU's? If so, you might want to check out www.preludepower.com for more info.
Gregg
Hey, Adam, any update on this?
"Feed their greed with your need for speed"
hmmm. than can be a problem. Have you looked at a legend distributor? I really don't know how they mount but it might be something to look for. A 88-91 Civic SI distributor could be nice too.
I need these parts!
