Results 1 to 10 of 10
Thread: Voltage Regulator?
    Idaho
    Voltage Regulator?
    When I hit the gas, my lights get brighter, battery light comes on, voltage meter goes to 18 volts, WTF?
    Jareds 89 LX-i's Avatar
    Apr 2001
    Black '89 Accord LX-i sedan
    Mills River, NC
    Whoa.... if it's spiking to 18 volts the regulator is definitely shot.... it should never go above about 14.5 volts or so regardless of RPM. Replace that ASAP before you fry something important!
    -Jared
    Idaho
    Damn, the alternator is brand new, about 3 weeks ago i changed the alternator.
    1987 Hatchback phreak project
    NORTH BAY ONTARIO
    DEFECT!
    Travis
    Accord of the Year - 2008
    TWOLOUDNPROUD's Avatar
    May 2003
    I hate to tell you but it your alternater is bad
    Idaho
    This is the 3rd one in 1.5 years, 2 in 3 months, 3rd in 4 months. "But lifetime warranty baby!"
    Oct 2001
    87 Accord EX , 5spd , Manual
    if you chaneg your alternator that often ! why don't you check your wiring ! may be something is bad ! but as you said liftime warranty ! so replace every week if you want !
    Mike !
    Idaho
    How could my wiring be bad?
    Apr 2001
    Mills River, NC
    Well if the alternator isn't recieving proper battery signal voltage, then it thinks the battery is low and needs to boost charging. Here's a simple test to try on the wiring....
    1) Disconnect the alternator connector from the alternator. With the ignition switch on, there should be battery voltage between the IG (BLK/YEL) terminal and body ground, and between the S (WHT/GRN) terminal and body ground.
    2) If there is no voltage, check for:
    -Blown No. 1 (15 A) fuse in the dash fuse box
    -An open in the BLK/YEL wire between the dash fuse box and the voltage regulator, or the WHT/GRN wire between the under-hood relay box and the voltage regulator.
    -Jared
    Idaho
    mmmmm.........too cold outside and too much snow.
  1. voltage?
    By terry in forum Classic Honda Community Chat
    Last Post: 09-08-2012, 01:53 PM
  2. voltage regulator
    Last Post: 02-09-2008, 05:54 PM
  3. output voltage question
    By mykwikcoupe in forum Interior & Exterior Care
    Last Post: 10-18-2004, 06:52 PM
  4. EGR Lift Sensor Voltage
    By k-roy in forum 3geez Accords
    Last Post: 07-20-2004, 02:13 PM
