I got some 17x7.5 rims and was wondering could I put it on a 89 accord with no prob of rubbing?... Does anyone else have 17 on there accord?
OK
OK
your best bet is to test fit it with the tire and mag on it. then crank your steering wheel both ways and see if you get any rubbage.
Look at the inside of one of the rims for the offset, it should be stamped along with the wheel size info. It will say the size in mm or with a funny marking that looks like JJ. Hopefully you have 40mm or 42mm offset. I need to know what the offset is before I can answer the question whether or not they will fit, since you really can't go lower profile then 205/40 with 17" tires. I've never seen anything lower profile in 17" than that.
Now I d
