ok, i got the lude tranny from an 87 si, and everything went really smoothly with the swap. exept, a couple things. first, the lower motor mount has three bolts, one of which is threaded, the other two (the lower ones) are off by about 1/4 inch. the tranny needs to come up and a little towards the back of the car, but when i jack it everything moves and they don't line up anyway. any suggestions??? and the second problem is that aluminum plate type thing kind of in between the flywheel and block, two of the bolt holes on that aren't lining up right either, they are barely off but i can't seem to move the plate enough to get them lined up. it's really starting to piss me off so if anyone knows whats up with this i'd really appreciate the help. thanks
