Results 1 to 6 of 6
Thread: Koni shocks help
    1988 Honda Accord DX Sedan
    San Bruno, CA
    Koni shocks help
    How can I tell if my Koni's are blown?
    Based on other shocks I've used, when you compress the piston rod on the shock to the bottom, it rebounds back up by itself. But on the Koni's when I compress them to the bottom, they stay there. I was told that is suppose to be that way. Is that true?
    What settings should I begin out with on them? I am using Sprint springs. Most people on here say 1 full turn out from softest?
    86 Honda Accord LXI HB 5-sp
    Central California
    Quote Originally Posted by buish
    Koni's red's are not gas charged, so it's not possible for them to move back up when you push the piston rod down since they have no gas pressure to push them up. Basically their are three main types of shocks and struts, Hyrdaulic (not gas pressurized), low pressure gas charged twin tube and mono tube high pressure gas charged (Bilstien's).
    Only use the 1 full turn for softer lowering springs, like the H&R's and Neuspeeds. Sprints are plenty stiff, use 1 1/2 turns. The Koni's are off course shipped set to full soft.
    Now I d
    San Bruno, CA
    jim, can you rephrase your first sentence? so its "not" possible for them to move back up when the piston rod is down b/c they are not gas charged?
    carotman's Avatar
    Montreal South Shore
    Mine did the same thing. They would not come back. I guess it's normal. However. My friend's integra struts would come back up (they are Konis)
    I need these parts!
    Oct 2003
    B20A SEi
    Oregon City, Oregon
    The Koni's are not under pressure like some "gas charged" shocks. They stay where you put them, up, down or middle. I'm not sure how to test if they are blown, but on the stiffest setting, it's almost impossible to pull the rod back out after fully compressed (by hand), at least they were on mine when I bought them.
    Gregg
    Central California
    Yeah, sorry about that, I edited my post and added some info.
    Now I d
  1. KONI red front shocks (not mine)
    By bryan6732 in forum Classic Honda Community Chat
    Last Post: 06-14-2012, 12:28 PM
  2. Are these shocks on ebay koni? All 4 for $50
    By neoblue89lxi in forum Suspension/Wheels/Tires/Brakes
    Last Post: 09-20-2003, 04:20 PM
  3. koni shocks... where to buy??
    By modu03 in forum Suspension/Wheels/Tires/Brakes
    Last Post: 08-25-2003, 07:26 AM
  4. Ok well I'm getting new Koni shocks!!
    By Mike89Accordcom in forum Suspension/Wheels/Tires/Brakes
    Last Post: 02-09-2003, 04:03 AM
  5. OK....I've seen a number of shocks but...(? on koni's)
    By jteuton in forum Suspension/Wheels/Tires/Brakes
    Last Post: 10-11-2002, 08:05 AM
