Results 1 to 3 of 3
Thread: Fast idle
    Nov 2003
    1988/honda/accord lx
    Fast idle
    I can lock my fast idle manually by holding the choke valve closed and pressing the accelerator, thats fine. But when I just press my accelerator when the car is cold to engage the fast idle it doesn't engage even the honda factory manual doesn't help can anybody here help
    Thanks
    LX User DanG86LX's Avatar
    Jun 2002
    86 Accord LX, carb, AT
    Edmonton, Alberta
    Guess, the answer is in ur post! Check choke flap position:
    With engine cold < 25*C, the choke flap should be closed, due to bimetallic spring in the choke housing. When that happen, through a series of levers and springs, the Fast Idle Cam is tensioned to be set (when u blip the gas before startup).
    Proly ur choke flap is not closing when engine cold.. U may have to open choke housing by drilling 3 rivets and inspect that bimetallic spring..
    Probably the thermovalves...to check:
    (Engine cold (<--recommended) or hot)
    1st, with the engine off, close the choke with your hand, hold it closed, and with your other hand open and close the throttle. Now turn it on but don't touch the accelerator. If you get fast idle you choke settings are fine. Now, while the engine is on, tap the throttle. If it goes down to normal idle and won't go back up with the engine cold that means the thermovalve which opens the choke is stuck and should be replaced.
    Eric
  1. EFI fast idle
    By shepherd79 in forum 3geez Accords
    Last Post: 12-11-2003, 07:59 AM
  2. EFI fast idle
    By shepherd79 in forum EFI Tech
    Last Post: 12-10-2003, 04:57 AM
  3. is there a way to lower my fast idle, but keep warm idle the same?
    By bobafett in forum Classic Honda Community Chat
    Last Post: 03-20-2003, 05:44 AM
  4. Fast Idle
    By accord19882002 in forum 3geez Accords
    Last Post: 11-27-2002, 03:11 PM
  5. Fast Idle
    By locknload68 in forum Carburetor Tech
    Last Post: 10-01-2002, 05:40 PM
