Results 1 to 22 of 22
Thread: Popping out of reverse???
    89 LXI
    Maryland
    Question Popping out of reverse???
    Ok fellas here's the deal, I just did a tranny swap and installed a manual tranny, adjustable short shifter and a new ACT II clutch..... It shifts into gears 1-5 with no problems but when I put it into reverse it pops out after like a second or two.... I tried holding it but all it did was still pop out and grind a little.... I tried giving it more gas and letting off the clutch real easy but it did it again.... Now, I'm thinking that maybe my shifter may be adjusted little too short and that might be causing the problem but then wouldn't it happen to all of the gears as well if that was it??? So what do you guys think???
    'A20A3''s Avatar
    Mar 2003
    '89 LXi Coupe
    eastern shore, MD
    Sounds either linkage or clutch related. Check all your cables and make sure everything is accurate.
    -Harvey
    k-roy's Avatar
    87 LX
    This may not be the problem but a similar thing happeded to me. While in 5th it would pop out of gear. The tranny was low on fluid. make sure it all the way up to the fill plug. Keep pouring it in untill it starts to leak out.
    Or you could just need an adjustment on the linkage/shifter.
    89 LXI
    Maryland
    I'll check the fluid level but if it was the fluid level wouldn't effect the rest of the gears as well???
    Oct 2000
    '88 Accord LX-i
    Connecticut
    I know 5th and R sit higher than the rest of the gears. Also, your reverse gear may be shot.
    '88 LX-i Coupe --- LS/Vtec
    89 LXI
    Maryland
    Well, lets just pray that you're right about 5th and the reverse gear sitting higher than the rest of the other gears.... If this is true than maybe it is the fluid level because when I filled up the tranny, it had jack stands under the front wheels so maybe the tranny isn't as full as it needs to be....
    the car should be on the ground when you add oil.
    89 LXI
    Maryland
    I'm starting to think that the fluid level is the problem.... Now I can't wait to get home..... The thing is I hope I haven't caused any problems driving it....
    Justin86's Avatar
    Medford, Oregon
    Yea I made that mistake of filling it with it still raised. There is a ball and detent that is suppose to hold it in gear but if that was missing you would have problems with 5th too.
    89 LXI
    Maryland
    :angry: OK guys, fluid level isn't the problem here.... I filled it up last night and it was doing the same thing.... The only thing left to check is the height of the short shifter because maybe if I have it too short than that could cause it to pop out of gear.... If it doesn't turn out to be that then I'll probably end up taking it to the shop to have that reverse gear fixed.... I just don't understand it, all the other gears are fine, it's just the damn reverse thats keeping me from working out all of the kinks from this mani. swap as well......
    Justin86's Avatar
    Medford, Oregon
    Well you might want to take it out your self if you can't fix it by adjusting the shifter. Paying some one to work on a tranny is not cheap esp if they have to take it out and install. It would take about 5hrs just for the removal and install and then you have the tear down of the tranny, thoses costs would add up fast.
    89 LXI
    Maryland
    Problem with that is I can remove and install a tranny but when it comes to tearing it down I don't know if I can handle that, mainly because I don't know what I'll be looking for.....
    Justin86's Avatar
    Medford, Oregon
    Quote Originally Posted by joker2
    True but hopefuly it is something basic hopefuly it is. You might want to try to do it and hope for the best. Maybe something just came loose and are tranny's are actually quite simpile.
    Joker2,
    What kind of oil is in there?
    89 LXI
    Maryland
    I have Honda manual tranny oil and one bottle of Lucus..... You never now how much you take going in reverse for granted.... This really pisses me off... :angry: :angry: I adjusted the shifter and it's still doing the same thing.....
    Justin86's Avatar
    Medford, Oregon
    Well the next thing is to pull it. Think you are pissed I had to pull mine 7X before I finally got everything right.
    89 LXI
    Maryland
    I think I might just take it to this Honda specialist shop that I know about around the way and see what they say because I've been working on this car for like 2 months now and I'm not trying to climb back under it again.....
    Justin86's Avatar
    Medford, Oregon
    yea that would be a good idea to get some other opinions on it before you pull it.
    Try to disconnect the linkage all together. Then put in reverse with a cresant wrench,start engine with clutch in and see if it stays engaged.
    89 LXI
    Maryland
    Now that I might try!!! So if it doesn't stay in reverse after that then it has to be the reverse gear....
    Justin86's Avatar
    Medford, Oregon
    well that would help to figure out if the prob is in the shift linkage but all the other gears are working fine so it would be a waste of time but if time is no prob then go ahead and try it but I don't think you will get anything out of it.
    89 LXI
    Maryland
    No, time is a problem because this car needs to be out on the road and not sitting in my garage from a bad reverse gear or something..... :angry: The thing is I'm not trying to spend a lot of money on this repair so if I knew how to do it myself I would have already but I know if I open the thing up I'll probably mess it up worse than it already is......
  1. 5th Gear Keeps Popping out...need help
    By integrapwnage in forum 3geez Accords
    Last Post: 05-31-2009, 08:08 PM
  2. popping?
    By pervasto in forum 3geez Accords
    Last Post: 07-03-2004, 08:02 PM
  3. popping brakes
    By deadlight in forum 3geez Accords
    Last Post: 08-13-2003, 01:19 PM
  4. dipstick is popping out
    By GhEtTo 88 HB DX 5spd in forum 3geez Accords
    Last Post: 11-15-2002, 05:03 AM
  5. popping noise?
    By 86dxautohatchback in forum Carburetor Tech
    Last Post: 10-20-2002, 11:21 PM
