Well this happend when I first replaced my upper radiator hose. Where the rad. hose connects with the thermostat housing is where the problem is. I noticed that after the car heats up that it seems to smoke (burning off a little coolant) it's just very little b/c I don't notice a change in coolant levels. It looks like the hose might not be tight enough. I tightend it up before (right when I changed the hose and then I saw this problem and then really tightend the clamp) Well its doing it again so maybe it just loosened up. I didn't think those screw clamps loosened unless you did it yourself. So if anyone else has had this problem please tell me what you did to fix the problem. The hose is about 1.75 years old.
-Mike
