Results 1 to 3 of 3
Thread: Noise/Heat when car is put under stress ...
    Jul 2003
    89 Accord Hatchback DX
    CA
    I have an '89 Honda Accord Hatchback carb. Recently, when I drive the car up a ramp to change the oil, which requires using some acceleration & the brakes at the same time, a loud continuous noise starts coming from the engine area and heat immediately starts to enter the passenger compartment (even though vents/heat is turned off).
    I am not sure what the sound is, but sounds like a loud motor comes on, or a bad bearing noise. I turn the car off when this happens. Didn't see engine thermostat showing overheating, but didn't wait for it to happen either. Twice now this has happened. Afterwards, in regular driving, have never had this happen so far. I am concerned something is about to go bad.
    Hopefully somebody has some idea what might be happening here.
    Many thanks, JT
    2006 Nissan 350z
    Does school count?
    Rod knock perhaps? Now that I got my foot in, I would first have the car parked and have an assistant put some load on the engine while you listen carefully to the engine to determine exactly where the noise is eminating from. After you have done that, I will offer more suggestions as it would be useless and wastefull for me oranybody else to ascertain you problem over the internet.
    Make sure that Vent is set to HI-Low and to Recycled air instead of fresh.
    natsugusa ya
    tsuwamono domo ga
    yume no ato
    Jul 2003
    CA
    zero.counter, thanks for the response. I am afraid to induce the problem on the car again unnecessarily, in case I cause any damage.
    It sounds like more of a continuous sound rather than a knocking or tapping sound. Also immediately I notice pretty intense heat coming back into the drivers compartment. Is this something that is consistent with 'rod knock'.
    I am not that familiar with car problems, so any ideas would help.
    Also if any additives or higher octane gas might slow the progression of the problem.
    Thanks, JT
  1. Replies: 19
    Last Post: 05-05-2012, 02:35 PM
  2. No heat
    By dani_ocean in forum 1geez Accords
    Last Post: 10-17-2009, 06:01 PM
  3. Heat
    By Whistler225 in forum 3geez Accords
    Last Post: 04-08-2006, 03:24 PM
  4. Need Better Heat
    By BIGEEZ in forum Classic Honda Community Chat
    Last Post: 12-02-2003, 08:47 PM
  5. NO heat, NO A/C
    By markmdz89hatch in forum 3geez Accords
    Last Post: 12-04-2002, 06:34 AM
