Results 1 to 7 of 7
Thread: Replace whole axle or just cv boots?
    Aug 2003
    87 Honda Accord LX-i auto & manual 88' Honda Accord LX auto
    Antioch, CA
    I just bought a second accord and it makes a cracking noise when I make turns going slowly. I was about to change the whole axle but is it neccessary? Or could I just replace the cv boots? Thanks
    Vinny's Avatar
    Aug 2003
    Here, not there
    Its cheaper and easier to change the whole axle since you can pick them up new for around 50-60 bucks with a lifetime warranty
    shepherd79's Avatar
    Falling Waters, WV USA
    ifyou go to autoparts stores, you will find that outside CV joint will cost about $80-90.
    when you can get the hole axel for $50-60.
    k-roy's Avatar
    87 LX
    If you want to go cheap you could wipe off the cv with a clean rag. Don't use any cleaners or degreasers. Then repack it with bearing greese and put a new boot on. The ideal thing to do would be to replace the whole axle since it is making noise.
    1987 Hatchback phreak project
    NORTH BAY ONTARIO
    your shaft is FUCKED... too much dirt got in, so now its worn out... you buy a boot when you catch it before its making noise.. go pickup a whole new shaft and replace it... even with new grease, teh shaft will get progressivly louder adn louder and more unsafe
    Aug 2003
    Antioch, CA
    Thanks Guys! Im going out right now to go buy new axles. Thanks!
    2.0Si User pimp86LX's Avatar
    2005 Mazda 3
    Ontario Canada eh.
    thats what i did kroy, but mine wasnt making noise so thats why i repacked it. It got another 20,000km on that axle too!
  1. Need Help...(trying to replace CV boots broke a bolt)
    By M3Galaxie in forum Suspension/Wheels/Tires/Brakes
    Last Post: 06-06-2007, 10:13 AM
  2. replace transmission-axle seal?
    By timber_cruiser in forum 3geez Accords
    Last Post: 11-22-2006, 04:17 PM
  3. Axle leak problem (axle will not go in the tranny)
    By Legend_master in forum 3geez Accords
    Last Post: 06-25-2006, 11:03 AM
  4. CV Boots
    By danronian in forum Suspension/Wheels/Tires/Brakes
    Last Post: 03-06-2003, 08:15 PM
  5. CV boots,
    By Mantis88LX in forum Classic Honda Community Chat
    Last Post: 08-31-2002, 11:18 PM
