i just changed my plugs..i replaced them with the correct ngk plugs and when i started my car it runs fine for all of 10-15 seconds and then the idle jumps to 1900rpm and then falls to 1100rpm and continues to do this constant but i can give it just a little bit of gas to bring the rpms up to 2000 and it lines out ...it accelerates fine and decellerates fine but idles like i told you up down up down constantly..starts up fine also just so you know it started after i changed the plugs and i thought i might have damaged a plug wire removing them so i replaced them also and it is still doing it ...and it ran and idled perfect before please help ..this is my driver..my car is a 89 accord fuel injected 5speed LXI
