Results 1 to 25 of 32
Thread: Msd Sci
    Sabz5150's Avatar
    1989 Accord SE-i coupe
    Richmond, VA
    Msd Sci
    Snagged it for 140. Not a bad deal
    Bam!
    glorious!
    carotman's Avatar
    Montreal South Shore
    Looks exactly like mine
    It hides your VIN number however... cops might give you a hard time if they find out.
    I need these parts!
    Sabz5150's Avatar
    Richmond, VA
    Cops don't normally look for VINs, unless they think you stole the car.
    Normally is the key word though...
    glorious!
    Oct 2000
    '88 Accord LX-i
    Connecticut
    Quote Originally Posted by Sabz5150
    Got mine for $200 but mine has the rev limit control SCI-L
    No vin hiding on mine
    '88 LX-i Coupe --- LS/Vtec
    Sabz5150's Avatar
    Richmond, VA
    Quote Originally Posted by 88LXi68
    You don't have that friggin mystery box taking up valuable underhood real estate. I'm slowly working on thinning that bad boy down. I've eliminated three lines already. Anything to clean that bay up.
    Speaking of cleaning, that engine bay does need a good deal of washing.
    I was told that the MSD ignitions would cause bad interference noise in the radio. Suprisingly it didn't... actually cleaned up the noise that I had already. Radio sounds crisp now
    Performance wise, I gained a little bit of much needed low end and the engine is much smoother. All in all a great upgrade.
    glorious!
    1987 Hatchback phreak project
    NORTH BAY ONTARIO
    what exactly do the boxes do?
    Travis
    Sabz5150's Avatar
    Richmond, VA
    Quote Originally Posted by DXHATCHBACK
    Travis
    At 3000 and below they produce multple sparks for 20 degrees of crank rotation, drive more power to the coil and produce more reliable sparks at high RPMs (almsot no chance of missing at high revs). They also make your idle really smooth and improve fuel economy.
    Some models have pill adjustable revlimiters and can be outfitted with boxes to accomodate multiple pills for holeshot RPMs.
    glorious!
    SEi User ICEMAN707's Avatar
    Kissimmee FL
    nice find Sabz. you can relocate your battery to the trunk and place that box in place of the battery. that way it's far from the firewall and should reduce radio interference.
    hey 88lxi68, PM me a buildup sheet of that ls/vtec swap. i wanna know how you did it and what parts you had to buy. that's gonna be my summer project. thanks bro.
    Sabz5150's Avatar
    Richmond, VA
    Quote Originally Posted by ICEMAN707
    I have no radio interference. I had a bit of noise before I installed it and now it's nice and clean. Why? I have no idea.
    glorious!
    2.0Si User lightbulblxi's Avatar
    Aug 2003
    88 accord lx-i coupe 5sp.
    pulaski wisconsin
    good deal. i like the color of ur valve color.
    -Brian
    -"lifes a bitch,i swear to god, you take your chances, too many questions and not enuogh answers!"-nappy roots
    My Accord
    Busted_Blue's Avatar
    Jul 2003
    93 civic
    San Francisco, CA
    great deal! My MSD is hiding behind the firewall..in that little grill compartment where the wiper blades motors are in. That way less "nature" hits the MSD box prolonging it's life. It's been in there since 1990 and still running.
    The yellow wire runs up to the that upper left and then goes behind the firewall. If you take a look at my engine in person, you can see the MSD box throught those little square holes on the top.
    1988starter
    Guest
    no vin hiding for me BTW sabbs I would upgrade to This coil it made a hella difference for me.
    This coil
    10/Honda/Ridgeline
    NJ
    Stock Intake???????? WHere do u live man??? mars??????
    SEi User od2681's Avatar
    Nov 2002
    2003 Infiniti G35 sedan
    Houston Tx
    how are those with emissinos and engine life
    PhydeauX's Avatar
    Eastern Penna
    Carb certified, they come with the sitckers and everything. They don't effect engine life but you will go through caps and rotors faster espically if you run a hotter coil too.
    andy
    1988starter
    Guest
    Quote Originally Posted by PhydeauX
    andy
    Yup with my accel 14001 coil I tend to do a cap and rotor every 10k to be safe
    LX User catalin's Avatar
    1986 Accord Hatchback
    Surrey, BC, Canada
    Looks just like mine too...
    Except mine still doesn't do shit!
    Anyone of you try to wire it up with a replacement coil??
    Justin86's Avatar
    Medford, Oregon
    um your missing a radiator and going by your paint job I don't think the car is drag only.
    I would love to get rid of the damn emissions box and haivng the ignition were the wipper controls are is a pretty good idea but wouldn't it be more exposed to the weather?
    Surrey, BC, Canada
    Quote Originally Posted by Justin86
    It's a special air cooled edition Accord..
    At the time I was in the process of putting it the car together, and it will be a daily driver... No drag racing.
    I'd love to get rid of the emissions box too, but as of right now I don't have much of an idea how to do it.
    10/Honda/Ridgeline
    NJ
    catalin, i like ur paint. got more pics of your car?
    Sabz5150's Avatar
    Richmond, VA
    Quote Originally Posted by catalin
    If you're picture is showing how your car sits right now I can tell your problem. You gotta hook your coil wire to the blaster coil, not the stock one.
    glorious!
    Justin86's Avatar
    Medford, Oregon
    Yea the only way to get rid of the emission box is to go hack the ECU, which takes a lot of expensive programs... SEAN?
    Surrey, BC, Canada
    No it's running the stock one so I can get the damn thing around. But I did have the MSD coil only and I was getting a spark but the car just wouldn't start. At the time my alternator wasn't doing it's thing either because I made the mistake of powdercoating both brackets for it and didn't realize that it wasn't grounding. So I think that may be the problem but i haven't much time to try the MSD coil again.
    Surrey, BC, Canada
    Quote Originally Posted by smufguy
    you can find more pics at members.shaw.ca/ccapota
    10/Honda/Ridgeline
    NJ
    hey catalin, nice work on ur car man. I love the paint on ur brackets and valve cover. I would love to get my car painted in that color. What color is it? Dark gray metallic or something? That shit is awsome. I love the look of a clean engine bay and ur motor looks awsome. Good job buddy. props to you.
