Results 1 to 10 of 10
Thread: weird noise
    Nov 2003
    89 Honda Accord ex
    Canada
    weird noise
    When my car is running and i turn the wheel it makes a creaking noise sounds like the rack but not sure what could it be?
    Well my creaking noise was bad axles.
    Could be the case for you, but could be some suspension issues. Are you talking about when you are sitting at a stop, or when driving?
    Nov 2003
    89 Honda Accord ex
    Canada
    both when i turn the wheel it creaks
    10/Honda/Ridgeline
    NJ
    it does that only when its cold outside or does it do it all the time even after its warmed up? Check ur power steering fluid level. If its low change it. Also try and see if u can change the whole fluid.
    That creaking noise that u get is present when the car is not moving right? I have that these days due to the cold. Once the car warms up, there is no sound.
    Nov 2003
    89 Honda Accord ex
    Canada
    Blkblurr's Avatar
    Jan 2004
    Dayton, Ohio
    Mine was lack of lube on the bearings in the steering column / steering wheel.
    Oct 2001
    87 Accord EX , 5spd , Manual
    does it do that while standing ! ? or when driving ?
    Mike !
    Jareds 89 LX-i's Avatar
    Apr 2001
    Black '89 Accord LX-i sedan
    Mills River, NC
    If it's making a farily high pitch squeaking mostly when turning, then it could very well be a lower balljoint (or upper, but it's usually lower since they're load carrying balljoints). Could be a number of things though. Stick your ear right down by each wheel and have somebody turn the steering wheel, and see if you can trace down where it's coming from.
    -Jared
    Nov 2003
    89 Honda Accord ex
    Canada
    it only does it in cold weather but even when the cars warm it does it as long as it's still cold outside.
    SEi User danronian's Avatar
    1989 Honda Accord Lx-i, 1975 Chevrolet Malibu Classic
    Boyertown, PA
    You just need to take both wheels off, visually inspect all dust boots in the suspension, tilt the rotor (or wheel) all different directions to see if the ball joints have play, if they do, replace them. If the boots for the cv joints are ripped, and if they tick when you turn, replace the half shaft(s). Also check for play in the front wheel bearings. If none of these, I would bet it is either your steering column/wheel, or rack.
  1. weird noise
    By RAZR in forum 3geez Accords
    Last Post: 02-04-2012, 05:45 AM
  2. weird noise
    By poison2003 in forum 3geez Accords
    Last Post: 02-02-2011, 10:15 AM
  3. Weird Noise
    By bank2me in forum Suspension/Wheels/Tires/Brakes
    Last Post: 04-23-2008, 08:56 AM
  4. weird noise
    By hondanutt in forum 3geez Accords
    Last Post: 08-27-2006, 10:18 AM
  5. weird noise
    By mattdx88 in forum Interior & Exterior Care
    Last Post: 08-19-2004, 07:41 PM
