Results 1 to 9 of 9
Thread: oil pressure?
    2.0Si User lightbulblxi's Avatar
    Aug 2003
    88 accord lx-i coupe 5sp.
    pulaski wisconsin
    Question oil pressure?
    i installed an oil pressure gauge like a week ago, my question is when i first start the car, the pressure is 60-65 psi, and when im cruising, its aroun 40-45 psi, and warmed up and stoped, 20-25 psi. are these around what it should be?
    -Brian
    -"lifes a bitch,i swear to god, you take your chances, too many questions and not enuogh answers!"-nappy roots
    My Accord
    Idaho
    Yep,exactly what mine says.
    k-roy's Avatar
    87 LX
    I just looked it up in the service manual.
    Idle should be 14 psi minimum
    3,000 RPM should be at 56-65 psi
    It looks like you are doing ok.
    Idaho
    So does, this mean our engines are 100% good?
    k-roy's Avatar
    87 LX
    I can't make a guarentee on an engine I have not and never will see.
    If you keep up on all the small stuff and it runs strong you should have nothing to worry about.
    According to the manual your oil system is doing just fine. Just be sure to fix any leaks that pop up and change the oil every 3,000 miles and you will be allright.
    Idaho
    Sounds like she's going strong then........for 287,000 miles!
    Aug 2003
    pulaski wisconsin
    thanx guys, is there any other gauges that i could use to monitor stuff thats important like that? ive seen like volt meters and stuff, but how important are these?
    -Brian
    My Accord
    Jul 2003
    1987-Gen2 Honda Prelude-FF-2.0L-MPFI-4 Cyl-5 Spd-PWR-BLK
    Ottawa
    as your engine gets warmer it heats the oil and it gets thinner. I would bet this is the reason you see a drop in pressure when the engine is hot!
    k-roy's Avatar
    87 LX
    You can get the following gauges, probably a few more.
    Volt meter
    Air/Fuel ratio
    Fuel pressure
    Water Temp
    Vacuum gauge
    Exaughst Temp
    Basic temp gauge with probes to measure things like cylinder head or intake air
    What you go with depends on how concerned with the level of tuning.
  1. A/C no pressure
    By midnighttuner in forum 3geez Accords
    Last Post: 10-01-2008, 05:49 PM
  2. Oil Pressure?
    By Fuzy Navel in forum 3geez Accords
    Last Post: 11-10-2007, 10:11 PM
  3. Oil pressure
    By 89accordex4dr in forum 3geez Accords
    Last Post: 12-04-2005, 06:37 PM
  4. OIl Pressure
    By Morbid Intentionz in forum 3geez Accords
    Last Post: 08-30-2003, 06:46 PM
  5. a/t high pressure side vs low pressure
    By POS carb in forum 3geez Accords
    Last Post: 07-12-2002, 10:01 PM
