ive got an HX2 i wanna built a custom box for but it recommends that it has .8-4 cu. ft. of space. where would be the optimal space to be for the best sound??
here is a site with more info:
http://www.crutchfield.com/S-MhPFmb1...s&i=575RFD2212
-T.C.
Originally posted by HostileJava
are you making fun of me because I think coroncho80 is hot?
what do you want? you want nice sounding tight bass? or boomy loud sloppy bass? or do you want somthing in the middle?
Travis
There is a program that my friend uses to design boxes that fit a specific sub. Ill try and get the name for it and possibly a link.
Thinking about getting a new 3g...
its called WinISD the beta version is available for free...
anyway, if you want to use that program, make shur you know what your doing and what you want to get out of the box
Travis
i wanna get tight clean bass. i listen to alot of techno and rock.
-T.C.
build a 1.25 cube sealed box.. it will make nice tight bass that will play the techno and rock great
Travis
Then, no offense, but get a differant sub. The HX2s can get plenty loud, but are definately not very sq oriented (a.k.a. tight, clean, accurate, etc.). However if you already bought the sub and you will be sending it near it's rated power, take DXHATCHBACK's advice and build a 1.25 ft^3 sealed box or build a 2-2.25 ft^3 ported box tuned LOW. The less power you will be sending it, the bigger you will want your box (it will become more efficient and the lower frequencies will be a little louder, but it won't be able to handle as much power and will sound a little "boomier").Originally Posted by 88 Accord DX
-Ryan
Pure White 1988 DX Sedan
"It takes a big man to cry. And, an even bigger man to laugh at the big man crying"
also no offense, but why wouldnt hx2's be good enough?? i mean they're not spl speakers for competitions or anything, and he could mean he has a punch, not a power.....but im just curious.
I didn't mean to say that the HX2s weren't good enough, I just meant that there were better drivers available for the money. I was assuming he had (or was getting) the punch series because that was the link he posted. While the RF HX2 punch is more SQ oriented then other drivers from RF, it is far from a SQ sub. And it is by no means a bad sub (I consider it a pretty good sub), there are just better subs out there for the money. For example, the e12a from elemental designs is around the same price and has MUCH better SQ, a 3 year warranty, almost double the HX2s linear excursion, doesn't need such a large box, is more efficient, handles more power, can get louder, has a much more linear moter (will not lose BL), etc. Other subs include Brahma, Better Audio12, RE XXX, IDMAX, Magnum D2, mmats, Xtant, Diamond Audio and many others depending on the spl:sq ratio he wants, and the amount of money. The main reason RF drivers are so popular is because most people aren't aware that these other drivers exist, or else would rather just get a more mainstream driver that's widely available.Originally Posted by KoNEY
-Ryan
I bulit a box before with some cheapo wood from Lowe's , wood glue and my Dremel for about $30 total...... It worked ok for my Kicker Comps back then
My 1989 LX Carb. A.K.A. "Hoop Ride" (R.I.P.)
the type of wood depends on teh sound you want ....
I dig swap ash and maple personally
Kroy: Im a pro at smoking a blunt, talking on my cell, getting head, and shifting all at once
Dude,FU** LOWE"S.In da as$!(check my profile)Anyway I did the same thing for my kenwood 12's for a total cost of $8.00 Yes $8.00.That was including Titebond wood glue!I used 3/4" high density fiber board and made a 2.0^3 box for each 12 and it works great.Truthfully though it is very sloppy when I rock rage against the machine or METALLICA(rules).IT is verry loud if not super clean.But when I jam the Beastie boys it bumps hard enough to shake the cars next to me.Originally Posted by soljaboy2000
I'm a mushroom cloud layin' mutha fu**er,muthafu**er--Samuel L. Jackson in Pulp Fiction http://www.cardomain.com/id/mattalica13
If you can a make a custom bandpass i would definitely do it. I have just got an hx2 and I have it in a bandpass and it handles high and low frequencies really well. Search on the web and you can find ways to make custom boxes and how to calculate the sq footage.Originally Posted by 88 Accord DX
[IMG]C:\My Documents\My Pictures\avatar.JPG[/IMG] Hoody-
Projects:
Working on custom interior
new shocks
body kit
door handles fixed
custom trunk box
