Results 1 to 13 of 13
Thread: Oil level
    LXi User jlaccord89lxi's Avatar
    '01 Accord EX Coupe
    Nova Scotia, Canada
    Oil level
    I did an oil change on Sunday and now i've noticed that it is a little high. It is about 2-3 millimeters ( 1/8th inch) above the top circle on the dipstick. Is this bad? What kind of damage could potentially happen? To fix this can i just loosen the drain plug and let a little oil drain out?
    k-roy's Avatar
    87 LX
    You should be fine. you can drain a little out if you want.
    '01 Accord EX Coupe
    Nova Scotia, Canada
    ok, i just didn't want to have to drain the whole thing again...i don't know why i thought that. Someone had told me before that with too much oil in the engine, bubbles would form and cause trouble. I think i will attempt to drain a little out tomorrow, just for my own piece-of-mind. Thanks Kroy.
    Millington, TN
    "Don't bother"
    I run a 10 oz additive (Lubeguard) for the last 120,000 miles it always runs above the max fill line. No problems to date. Just don't add an extra quart.
    Hope this helps, LOL
    NSWST8
    Nov 2000
    I wouldn't worry about it at all.
    Bloodlust's Avatar
    1989 LXi Coupe (SOLD), 1998 Accord EX
    Line Lexington, PA
    Don't worry about it.
    '01 Accord EX Coupe
    Nova Scotia, Canada
    well if thats the concensus, then i won't waste my time. Chances are, it may burn a little anyway...i know thats not good either, but it'll save me adding in more later HAHA!
    1987 Hatchback phreak project
    NORTH BAY ONTARIO
    yah man... between the dots is 1 liter.. so if your that much over.. its like an 1/8th of a liter
    Travis
    1990/BMW/535iA
    New Orleans, LA
    Lightbulb
    Quote Originally Posted by jlaccord89lxi
    The only time you would get bubbles in the oil is when it starts foaming. This happens due to an overly high oil level in the oil pan. The moving parts contact the oil and beat it into a milshake consistency. When this substance is then forced through your engine, it's lubricative qualities are not good at all. In turn, that causes oil starvation and damages the engine. Generally, overfilling the engine oil may cause your crankshaft seal and many other seals to be pressed out by the increased pressure inside the engine. 2-3mm over the full mark won't hurt anything. My mechanic once overfilled the engine by a whole quart. After getting home I checked the oil and syphoned it out through the dipstick tube. That was the last time the mechanic touched my car. If you are really concerned about it, you could just take some clear tubing of appropriate diameter and force it down into the oil pan, then syphon out the required amount of oil.
    Hope this helps.
    3axap.
    '01 Accord EX Coupe
    Nova Scotia, Canada
    i drained some out today anyway. When i got home this morning and checked the oil level once the engine was warm, it was WAY above the top circle. I drained some out and i'll top it up again when the engine is nice and cool.
    2.0Si User lightbulblxi's Avatar
    Aug 2003
    88 accord lx-i coupe 5sp.
    pulaski wisconsin
    didnt kno too much oil could hurt.........
    -Brian
    My Accord
    2.0Si User Neuspeed87lx's Avatar
    Jul 2001
    96 Civic (Turbo lsvtec) /87 accord lx/95 civic dx
    Agawam, Mass
    yes too much oil can hurt .... but it dosent sound like he put to much in .... you will be fine with it a little overfilled .... how many quarts did you put in ?
    Jay
    '01 Accord EX Coupe
    Nova Scotia, Canada
    i don't really measure it as i put it in. I just pour some in and keep checking the dipstick. went a little overboard this time though. I drained some, so i'm fine now.
  1. Difficulty Level?
    By l3aLLa in forum 3geez Accords
    Last Post: 03-06-2006, 06:44 PM
  2. float level
    By Dutchboy in forum Carburetor Tech
    Last Post: 01-20-2005, 12:06 PM
  3. Level of one to 10?
    By BITESIZE in forum 3geez Accords
    Last Post: 07-15-2003, 11:45 AM
  4. Oil Level
    By The88Accord in forum Classic Honda Community Chat
    Last Post: 05-11-2003, 09:20 PM
  5. float level
    By shepherd79 in forum Carburetor Tech
    Last Post: 09-02-2002, 07:19 PM
