Results 1 to 5 of 5
Thread: need these questions answered please HELP
    Jan 2003
    1986 prelude
    charlotte nc
    ok so iv got 75 percent of my gasket and stuff iv contacted engine dealers and all of thise people but they dont knwo wither and i dont have these 2 part numbers so will someone help me
    i need to know which car i get this for or if i can only order it througfh japan and if so whats the part number
    oil seal that is the ring that is around the end of the crankshaft where the harmonic balncer connects do i get this from a lude or the a20
    and rear main seal lude or a20 which onew do i get it from please help
    k-roy's Avatar
    87 LX
    I know this is not the idea solution but it should work. Look in your yellow pages for a rubber and gasket compony. There is one down the street from me and they do custom work. You can take in your distributor and they can take the measurements they need. The only thing I can think of is the thickness may be hard to guess, so have 3 make of different thicknesses. This should be easier and take a lot less time than having one imported from Japan.
    S.Glastonbury, CT
    Just order them from Japan if your not sure it will be about the same as a dealer would charge just a little more for shipping. The rear main seal part number is 91214-PC6-013 i would try to search to see if its a USDM part as well. When it comes to seals if they are not exact your going to have a leak so if you dont know for sure from other peoples experiences then get the right part its not as hard as people think. And if you just need seals shipping cant be that much.
    Oct 2003
    B20A SEi
    Oregon City, Oregon
    Another thing you could try is take your old seals and go to a Honda Parts place and try to match them. I'd start with the B20A5 (88-91 Prelude si) parts.
    Gregg
    S.Glastonbury, CT
    Ok i decided to look for matching part numbers for some stuff and the only one i found a match for was the rear main seal. Its from a 1984+ CRX 1342cc and the part number is the same as the JDM 91214-PC6-013 also sizes as (80x100x10).
    So some things do match but none of the other numbers match so i think eventually you will have to order stuff from Japan.
  1. Few questions about carb parts, answered.
    By A20A1 in forum Carburetor Tech
    Last Post: 04-09-2006, 02:49 PM
  2. A couple of questions that need answered
    By ICEMAN707 in forum EFI Tech
    Last Post: 10-16-2003, 03:45 AM
  3. A20 intake manifold questions I have answered
    By 1988starter in forum Performance
    Last Post: 07-16-2003, 12:22 PM
  4. EFI Questions answered!
    By carotman in forum EFI Tech
    Last Post: 12-16-2002, 07:23 AM
  5. NEON ?'s MUST BE ANSWERED!!!
    By Chubs87Accord in forum Interior & Exterior Care
    Last Post: 09-04-2002, 09:41 AM
