Results 1 to 8 of 8
Thread: Thermostat is bad????
    LXi User soljaboy2000's Avatar
    Jan 2004
    1989 Honda Accord LX
    Hawaii
    Lightbulb Thermostat is bad????
    I know that can you tell if your thermostat has failed if it fails in the closed position by the overheating. etc. But if it has failed in the open position how can you tell? Are there any signs?
    My 1989 LX Carb. A.K.A. "Hoop Ride" (R.I.P.)
    k-roy's Avatar
    87 LX
    If it fails in the open position it will take forever to warm up.
    If you are in doubt of it you should just replace it. Its a $5 part.
    Jan 2004
    Hawaii
    what temp it is when needle is 2/3 the way up?
    Nov 2002
    1990/BMW/535iA
    New Orleans, LA
    it is hard to say what temperature the engine is at by the needle position. It is mostly there to give you a relative indication of how your engine is doing. My temperature gauge usually stays at a little below 1/2. 2/3 of the way up is a little hot. If you suspect your thermostat, it is a good idea to just replace it. Some thermostats have a safety feature allowing them to fail only in the open position. A thermostat stuck in the open position will cause your engine to warm up very slowly, it can also cause the engine temperature to vary based on the speed at which the car is moving (fast=cool down).
    3axap.
    Jan 2004
    Hawaii
    if was to take it out to inspect it, what should I look for?
    Dec 2003
    Millington, TN
    It's bad
    Throw it in a pot of boiling H2o you will see it open at about 185 degrees if it doesn't its bad and check your sending unit.
    hope this helps.
    NSWST8
    'A20A3''s Avatar
    Mar 2003
    '89 LXi Coupe
    eastern shore, MD
    Dude, if you're gonna take it out save yourself the time of having to replace it later on and just replace it.
    Like it's been said before it's cheap, and make sure you get a new thermostat housing gasket as well.
    -Harvey
    Jan 2004
    Hawaii
    yeah imma get new one
  1. thermostat, which one?
    By djcslice in forum 3geez Accords
    Last Post: 10-06-2006, 08:42 AM
  2. Thermostat bad?
    By Underdog in forum 3geez Accords
    Last Post: 02-13-2005, 05:14 PM
  3. Thermostat
    By Elijah in forum 3geez Accords
    Last Post: 01-31-2004, 07:56 PM
  4. thermostat
    By 89accordex in forum Carburetor Tech
    Last Post: 01-11-2004, 10:27 AM
