Results 1 to 11 of 11
Thread: dics vs drums
    2.0Si User lightbulblxi's Avatar
    Aug 2003
    88 accord lx-i coupe 5sp.
    pulaski wisconsin
    Question dics vs drums
    i keep hearing people talk about doing a swap to discs in the back. i was wondering waht are advantages/disadvantages of discs/drums? if discs are better, is there any way to upgrade the rear drums to perform as well? and input would be appreciated.
    -Brian
    -"lifes a bitch,i swear to god, you take your chances, too many questions and not enuogh answers!"-nappy roots
    My Accord
    k-roy's Avatar
    87 LX
    FUCK REAR DRUMS!
    You are not going to get them to perform any better.
    Drums are shitty, drive a car with drums on all 4 wheels and you will know what I mean.
    Drums lock up easy and do real crappy in the rain. Plus they fade a lot more.
    Discs rule!
    Aug 2003
    pulaski wisconsin
    does that have something to do with the drums are heavy, so it takes more response time, and the discs are lighter, so it takes less response time?
    -Brian
    My Accord
    k-roy's Avatar
    87 LX
    Quote Originally Posted by lightbulblxi
    It has nothing to do with weight, drums blow worse than Barbera Streisand.
    Drums are cast iron and use rubber shoes.
    Discs are steel and use carbon/metallic (whatever there are tons of types of pads).
    Discs clamp and drums drag.
    'A20A3''s Avatar
    Mar 2003
    '89 LXi Coupe
    eastern shore, MD
    Kroy is right...again. :cool2:
    However, the SE-i rear calipers are infamous for seizing, so be careful if you swap. In the long run it's worth the time and money though.
    -Harvey
    Aug 2003
    pulaski wisconsin
    is there any other way to swap, because se-i are rare around here.
    -Brian
    My Accord
    'A20A3''s Avatar
    Mar 2003
    '89 LXi Coupe
    eastern shore, MD
    You could possibly use Civic or Prelude...I'm not sure...
    -Harvey
    k-roy's Avatar
    87 LX
    The calipers are off the shelf parts used on various models. But you still need other peices.
    You can use www.hondaautomotiveparts.com and lookup a 3G and compare some part #s with other models.
    2.0Si User Neuspeed87lx's Avatar
    Jul 2001
    96 Civic (Turbo lsvtec) /87 accord lx/95 civic dx
    Agawam, Mass
    disc brakes are lighter.... and produce less heat.... acually i should say they dissapate heat better.... they are more responsive than drum brakes....i hate drum brakes.... disc are much better imo
    Jay
    PhydeauX's Avatar
    Eastern Penna
    I've converted every car I've ever owned to disks. I've always done it for the feel. They're also easier to work on. I just swaped a bad caliper off my jetta took under half an hour taking my time. Try doing a wheel cylender in that. You need the hub carriers from an 89 se-i because the caliper mounts are cast onto them, the rest of the parts are easy to come by. There was a thread a while ago where someone had claimed to have made gen 1 integra disks work. I believe the integra sandwiches the caliper mount between the hub and carrier so theoreticaly it could be possible provided the integra hubs have the same footprint as the accord. No one ever proved/disproved it.
    andy
    Busted_Blue's Avatar
    Jul 2003
    93 civic
    San Francisco, CA
    how much would the rear disc conversion cost?
  1. Se-I prop valve and M/C on DrumS car?
    By johnnygo in forum Suspension/Wheels/Tires/Brakes
    Last Post: 11-06-2008, 08:05 PM
  2. problem w/ rear drums
    By spanky in forum Suspension/Wheels/Tires/Brakes
    Last Post: 10-31-2005, 11:17 AM
  3. how do I get the rear drums off? :mad:
    By 2old_honda in forum 3geez Accords
    Last Post: 11-22-2004, 06:55 PM
  4. Brake drums
    By anchovies in forum 3geez Accords
    Last Post: 10-10-2002, 12:08 PM
  5. shining up calipers and drums???
    By 89accordlxi in forum Interior & Exterior Care
    Last Post: 09-13-2002, 12:59 PM
