Results 1 to 16 of 16
Thread: my indash thermostat is always on COLD
    LXi User Dennis's Avatar
    Dec 2003
    88 Honda Accord LX, 96 Kia Sephia RS
    Kentucky
    something is wrong with my thermostat in my dash (next to my speedo and fuel gauge) i don't even know where to start trouble shooting... :cool2:
    k-roy's Avatar
    87 LX
    I say change your thermostat in the cooling system. Its probably seized in the open position not allowing your car to funny warm up. Try that first, its a routine maintaince $5 part. If its not that then it is probably a bad sensor. Does your heat work?
    A20A1's Avatar
    Sep 2001
    2006 Chevy Cobalt LS
    Check your coolant level first...
    Make sure the wire is still connected to the sensor on the back of the intake manifold.
    LXi User soljaboy2000's Avatar
    Jan 2004
    1989 Honda Accord LX
    Hawaii
    There's a sensor on the intake manifold? I thought on was on the back of the block?
    My 1989 LX Carb. A.K.A. "Hoop Ride" (R.I.P.)
    Dec 2003
    Kentucky
    yeah my heat still works, not really good though. i'm tall so i sit basicly in the back seat while driving and by the time the air gets to me it's already cold... anyone have diagrams to what i should look for? thanks.
    Jul 2003
    1986 Honda Accord LX
    MS
    Would be a good time to invest in a 86-89 Accord Manual, I may look it up in a little while if I get off the computer, the manual is $10 USD at any parts store... You didn't mention if the car was running poorly? Does everything run properly except the gauge?
    k-roy's Avatar
    87 LX
    I say replace the thermostat to start, its cheap.
    Dec 2003
    Kentucky
    the car runs fine, makes alot of noise under the hood. sounds like blowing and sucking but i don't know. i'll get it checked out.
    Dec 2003
    Kentucky
    aaaaaaaaaaaa
    LXi User johnwc723's Avatar
    Feb 2003
    89 LX-i 5 speed
    Madison, WI
    heh yeah i have the same problem i htink its my thermostat do you get bad gas mileage? i get about 14mpg at the moment...
    Nov 2003
    89 Honda Accord ex
    Canada
    never heard of a bad thermostat causing bad gas mileage.
    DX User Sweet86Lxi's Avatar
    Oct 2003
    86 Honda Accord
    Louisville, Kentucky
    yea i had that mainly happen to me except the person before me that had my car actually took the thermostate out, so i finally realized it but it wasn't all that expensive.
    mat
    weeeeeeeeee
    Dec 2003
    Kentucky
    yeah i've been getting gas almost every day 3-5 dollars worth... thats alot compared to my old car which only had a 1.8, but then again, it was a stick. Anyways, yeah I've noticed the bad gas milage too.
    Feb 2003
    89 LX-i 5 speed
    Madison, WI
    just go buy a new thermostat asap make sure you point the "non spring side" towards you when you put it back in, this is probably your problem, and its bad for your car to run cold and it give you TERRIBLE gas mileage. i just fixed mine finally i put a honda OEM on in there much more substantial than the ones at an auto store...
    for the oem gasket and thermostat it only cost $16, its alot cheaper than buying gas all the time... warm car! and better preformance
    Dec 2003
    Kentucky
    anyone have a link to the thermostat i need? i'll get one today before i go to work but i won't be able to put it in until tommorow. you think i'll be ok? it seems like my car doesn't get any power either... could that also be a problem? it's hard as hell for me to get my car past 90mph.
    A20A1's Avatar
    Sep 2001
    why are you going 90?
    Fix one thing at a time...
    anywho your milage problem might be linked to an ignition problem or a carb vacuum leak... or a slightly loose booster venturi... which might explain the hard time getting past 90, but a loose booster usually would mean less gas is used which means your low gas milage is just the factor of you driving too fast...
    If the manifold and carb heater is working properly, you should get better milage in cold weather. Someone suggested a 192/195 thermostat I believe for the cold weather. The ones I see in autoparts stores are made by stant I think... or maybe that was just for the radiator caps. Just ask the person at the counter for the part #.
  1. Which thermostat?
    By nfs480 in forum 3geez Accords
    Last Post: 10-05-2008, 07:12 PM
  2. thermostat, which one?
    By djcslice in forum 3geez Accords
    Last Post: 10-06-2006, 08:42 AM
  3. Thermostat bad?
    By Underdog in forum 3geez Accords
    Last Post: 02-13-2005, 05:14 PM
  4. WTB: indash CD player
    By 3G Jester in forum Trading Post
    Last Post: 01-07-2004, 04:49 AM
  5. indash TV.
    By RED LXI in forum Interior & Exterior Care
    Last Post: 09-27-2003, 11:04 AM
